CEL stays Solid when jumpped
Old Aug 14, 2012 | 06:00 PM
radicaled434's Avatar
Default CEL stays Solid when jumpped
Old Aug 14, 2012 | 07:48 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: CEL stays Solid when jumpped
Originally Posted by radicaled434
Car Info:
-00 Civic Ex
-B20 (stock)/GSR trans (stock)
-2005 Gauge Cluster
-Phearable non-vtec ecu
Dunno, the Civic forum may be of better help.
Old Aug 15, 2012 | 12:39 AM
holmesnmanny's Avatar
be sure ur using a paperclip that's conductive.
Old Aug 15, 2012 | 12:56 AM
Swap'DShuttle's Avatar
Is there anything wrong? I mean if its running perfect no codes and you get a solid cel, I'd just keep a spare ecu if anything happened and call it a day.
Old Aug 15, 2012 | 09:55 AM
jdmcertified909's Avatar
solid cel means bad ecu/bad ground/no power to ecu. so check those too. make sure your getting power and ground
Old Aug 15, 2012 | 12:34 PM
GhostAccord's Avatar
Wrong..... A solid CEL with the SCS connector jumped means that there are no stored codes on the ECU. A code 0 or no CEL flashes with the SCS connector shorted is the code for a bad ECU......and a solid CEL without the connector shorted means that there is an issue with one of the PGM-FI systems on the ECU and it is running in backup mode (limp mode).
Old Aug 15, 2012 | 01:23 PM
weird cuz ive had a friend of mine with a ecu fuse blown and it was giving a solid check engine light when jumped after replacing fuse it was normal......
Old Aug 15, 2012 | 02:00 PM
Was it also a solid CEL (already in limp mode) without the SCS jumped?
Old Aug 15, 2012 | 02:15 PM
the light is solid(dim) when normal driving, i have a shift light at 6800rpms so cel brightens up at 6800rpm
when i park the car, turn it off, and jump the ecu, turn the key two clicks and the light starts dim then gets bright and doesnt blink
Old Aug 15, 2012 | 06:00 PM
v4lu3s's Avatar
RTFM
sounds like a bad ecu or bad program on the ecu.
Old Aug 16, 2012 | 12:02 AM
Well seeing as how he said it did it on two different ECUs. I'd go with a bad program/EPROM chip or a wiring issue.
Old Feb 23, 2013 | 05:06 PM
gnxpro24's Avatar
Sorry to revive an old thread but, I see youre online atm, Ghost Accord. I just chipped a p28 for my obd2 prelude with a Phearable chip kit and am getting a solid cel but when I plug in a stock p28, it will allow the cel to flash
Old Feb 23, 2013 | 06:25 PM
What is the stock P28 showing for codes?
A solid CEL with a chipped ECU could be a number of things. Bad solder, improper EPROM. You should be able to get the same flashes from a chipped ECU.
Do you have any tuning gear, ie a laptop and Datalogging cable or know anyone who does?
Old Feb 23, 2013 | 06:31 PM
gnxpro24's Avatar
I have a laptop but no cable. Showing vtec pressure switch cause jdm motors have no pressure switch, so I added one now.
Old Feb 23, 2013 | 06:45 PM
gnxpro24's Avatar
Fixed it
350znal
Engine Management and Tuning
Feb 25, 2011 01:49 PM
rick_rabies
Aug 24, 2009 06:22 PM
Pfieff
Aug 31, 2003 05:23 PM
h8tred
Jul 7, 2003 08:35 PM
B18EG6
Nov 8, 2002 07:22 AM
