Help: What are the symptoms of a bad VSS sensor...
Old Aug 10, 2003 | 03:49 AM
00 FBP ItR's Avatar
Default Help: What are the symptoms of a bad VSS sensor...
Right now the Tach works, but the speedo doesn't.
the car is very "jumpy"...
ex. redlining 2nd gear.. when you "gas it" the revs climb as usual but then the power cuts in/out through out the revs.. as if you are "blipping" the gas as you "gas it"
This is on a 97 jdm h22a.
fyi: the motor is in a 94 accord.
What can be the problem???... i really need to fix this ****
Old Aug 10, 2003 | 04:58 AM
b19coupe's Avatar
Default Re: Help: What are the symptoms of a bad VSS sensor... (00 FBP ItR)
Symptom of a bad VSS is erratic or non-existent speedo operation. Also check the connector at the speed sensor carefully-look for greenish discoloration of the metal; have seen more than one inop speedo resulting from connector corrosion. The more common cause is a failed speed sensor though.
Old Aug 10, 2003 | 02:38 PM
00 FBP ItR's Avatar
Default Re: Help: What are the symptoms of a bad VSS sensor... (b19coupe)
Ok, that solves the speedo problem...
but what about the power cutting in and out?
Leandro Peņa
Honda Civic (2001 - 2005)
Sep 26, 2018 08:32 AM
forumnoobie
Jun 6, 2006 08:56 AM
iblingidawg
Dec 17, 2005 11:18 AM
bg-33p
Feb 12, 2005 10:33 PM
Mike95lude
Feb 18, 2002 09:50 PM
