Help, Speedo is Messed up.. (Searched already)
Old May 17, 2003 | 06:52 PM
92HB_HB's Avatar
Default Help, Speedo is Messed up.. (Searched already)
I know this has been covered millions of times, and i've used the search feature, but w no sucess.. the problem is not w/ the VSS because i haven't gotten any CEL's , and I have moved from an LS to a GSR swap and the problem still exists..
I susepect its the dam speedo cluster, but i dont have one to check it with.. how the heck can those dam things go bad? and is there a way to fix the problem w/o replacing it?? lastly, i'm not sure if the gsr vtec works when the speedo is not functioning.. I assume it would since the VSS is still working and sending a signal to the ECU.. Its jsut that the signal going to the dam Speedo cluster is not registering w/ the cluster itself... When the speedo is working though, I can feel the vtec, though its nothing compared to the pull of boost....
please help me figure out this dam problem b4 i go bezzerk...
blinger
11
Mar 26, 2024 08:08 PM
odogg726
Jun 23, 2007 09:39 PM
spaceman00
May 2, 2007 07:27 AM
TwoSaints
14
Jun 16, 2003 05:46 PM
andrew dc
Apr 29, 2003 07:11 AM
