Need help!
Old 06-04-2007, 06:06 PM
Diet coke boii's Avatar
Default Need help!
When my car is on my lights flicker.I have a good battery connection so idk why this is happening.
Old 06-04-2007, 07:08 PM
Default Re: Need help! (Diet coke boii)
bump
come on guys.
Old 06-04-2007, 07:26 PM
97Ej6mike's Avatar
Could be a few things like a bad ground somewhere, maybe a faulty fuse, alternator thats going, or a wiring issue. Id check Alternator first, then look for any bad grounds.
Old 06-05-2007, 12:34 PM
Default Re: (97Ej6mike)
Well I thought if it was a bad alternator it would stop flickering when reved high,and mine doesnt stop it flickers at all times when the car is running.I could be wrong.
Old 06-05-2007, 12:35 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: (Diet coke boii)
Check the fuse and grounds.
I'm betting $3 it's a fuse that's not connecting properly.
Replace the existing headlight fuse with a new/working fuse of similar amperage. I bet it solves your problem.
Old 06-05-2007, 12:41 PM
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Check the fuse and grounds.
Replace the existing headlight fuse with a new/working fuse of similar amperage. I bet it solves your problem.</TD></TR></TABLE>
Will this solve the flicker on all my lights?
Its everything cluster/tail lights/headlights everything
Old 06-05-2007, 01:35 PM
Ek Forever y0!
Oh, it's all your lights. Then it could be grounds or alternator.
Old 06-05-2007, 07:53 PM
Cool thanx
ek forever guy has awnsered like all of questions i've ever posted
Old 06-05-2007, 07:55 PM
Ek Forever y0!
I just try to help, i'm not the most knowledgeable, but I try to post useful information. And I'm on all hours of the day just about, because of my weird work schedule, so I'm always around when others arent.
Hope I helped
Old 06-05-2007, 08:33 PM
most deff
One other question could a tranny leak because of a bad rear main seal?
Old 06-06-2007, 06:49 PM
Still trying to figure out the flicker problem cant figure it out.All the fuses are good.What grounds and where are they that could cause this problem?
Old 06-07-2007, 01:15 PM
Bump
Old 06-07-2007, 01:23 PM
therealjaydubb's Avatar
Whats the year and model and motor type.
Old 06-07-2007, 01:26 PM
Default Re: (therealjaydubb)
see sig
Old 06-07-2007, 01:30 PM
Usually if its tranny fluid is leaking where it comes together with the engine its the transmission front seal.
Old 06-07-2007, 01:41 PM
ok im going to give u a list of things to check ...the main switch. The Dimmer switch, check the valve cover ground-should be black or brown, the battery ground, the black yellow gorund on transmission also check them for corrosion. But to me it sounds like the main switch.
Old 06-07-2007, 07:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealjaydubb &raquo;</TD></TR><TR><TD CLASS="quote">ok im going to give u a list of things to check ...the main switch. The Dimmer switch, check the valve cover ground-should be black or brown, the battery ground, the black yellow gorund on transmission also check them for corrosion. But to me it sounds like the main switch.</TD></TR></TABLE>
What main switch?
Old 06-07-2007, 08:16 PM
Ek Forever y0!
He's talking about the main relay.
Old 06-10-2007, 04:46 AM
Not only the relay but the actual switch on the turn signal, do the wiggle test to see if it clears up. check for excessive play in the switch.
Old 06-10-2007, 12:54 PM
ok
niceprelude
09-02-2011 06:58 AM
rhdc2itr
01-25-2008 08:43 PM
Cyrus4g63
10-09-2006 08:40 PM
george34
Audio / Security / Video
32
08-17-2006 12:47 PM
cruzersi99
11-24-2003 06:47 AM
Quick Reply: Need help!
