speedometer not working help!
Ok i made a full GSR swap in to a 97 civic ex and im using the P72 with stock wering harrnes. my speedo worked with the single cam so dont know whats up any help would be great.
Re: speedometer not working help!
3 things could be wrong..
1. VSS not working or broken or unplugged or corroded
2. Your alternator/vss fuse is popped! Get a new fuse I believe its fuse #15
3. Your speedometer is not working correctly. Replace it with another cluster
tips: If you find yourself stranded and your car dies, then its likely that the fuse popped therefore no charge is going to your battery from the alternator thus your speedometer isn't working either because they share the same fuse.
GRLwitDELSOL
10-27-2003 06:31 PM
