HELP on removing rear coolant line
swaping good parts of spare engine to other engine, need help removing the coolant line in the back...the one that goes parallel to the engine it metal not rubber. please post asap. thanks.
just take off the two 10mm bolts on the thermostat housing... The part that connects to the block.... Then slide the pipe off both ends.. They only have o-rings to help them seal...... So they should just pull out after the two 10mm bolts are out. hope this helps.....
I would replace the o-rings. They're cheap, and if it does leak you will be kicking yourself for not doing it right. I would also clean the corrosion (if present) from the areas where the tube connects.
EF7
Apr 22, 2008 04:41 PM
ScottEK
Oct 30, 2002 09:42 PM
