- HELP - How to replace Thermostat Case???
I just got me a 1999 Civic LX and the Thermostat Case ( Number 7) is corroded (actually has a hole in it).
Does anyone knows is it is possible to remove it without removing the intake manifold etc?
I already remove the 2 10mm bolts that attached it to the block.
I just need to separate the housing from the tube but it is not comming off.
Any help, ideas, pointers, directions, suggestions etc will be appreciated.
I did search but no luck so PLEASE keep this positive
Re: - HELP - How to replace Thermostat Case??? (EF7)
Got it out, it was held in place by a rubber gasket on the tube.
I sprayed some WD40 and pulled it out by moving it sideways
JimRaynor90
08-13-2014 07:23 PM
GroundZer0
08-29-2002 08:13 AM
