Help, installed MSD, wont start...
Old Dec 1, 2003 | 11:20 PM
JDMs1eeper's Avatar
Default Help, installed MSD, wont start...
MSD 6al Ignition
Heres what i did:
Red Big- I hooked to + Battery terminal
Black Big - Grounded to the frame near MSD box
Orange - Hooked to + Coil (Internal)
Red - Hooked to + Coil (internal)
Black - Hooked to - Coil (Internal)
White - Hooked to - Coil (internal)
I dont have the MSD external Coil... Did i do this right? It wont start, and when i unhooked all the wires and MSD it started up just fine.
Does MSD have a fuse I can check?
Old Dec 1, 2003 | 11:30 PM
JDMs1eeper's Avatar
Default Re: Help, installed MSD, wont start... (Typesi2nv)
I think i know what i did wrong. Do i need to do this
Connect these to the +/- coil
Orange + coil
Black - coil
Connect these to the existing wires that used to be connected to coil
Red + coil wire
White - coil wire
????? any one wanna help a fella out ????
Old Dec 2, 2003 | 04:38 AM
EE_Chris's Avatar
Did you know: Manufacturers of products, especially well known ones such as MSD, have a website that usually include a download section of manuals.
Hooking up MSD 6AL using internal coil for a Honda
Old Dec 2, 2003 | 05:10 AM
D-Man's Avatar
You have to cut some wires on that box so itll run on a 4 cylinder...its been so long since I had a 6al that I forgot which wires you gotta cuts..theyre in a loom,that you pull out and then you cut I believe 2 of the wires....anyone else know which color wires they are,I forgot
Old Dec 2, 2003 | 10:14 AM
JDMs1eeper's Avatar
Default Re: Help, installed MSD, wont start... (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Did you know: Manufacturers of products, especially well known ones such as MSD, have a website that usually include a download section of manuals.
Hooking up MSD 6AL using internal coil for a Honda</TD></TR></TABLE>
thanks for the link and sarcasim
Old Dec 2, 2003 | 10:15 AM
JDMs1eeper's Avatar
Default Re: Help, installed MSD, wont start... (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">You have to cut some wires on that box so itll run on a 4 cylinder...its been so long since I had a 6al that I forgot which wires you gotta cuts..theyre in a loom,that you pull out and then you cut I believe 2 of the wires....anyone else know which color wires they are,I forgot </TD></TR></TABLE>
I baught this used from a friend, so im sure if that needs to be done then he already did it thanks
Old Dec 2, 2003 | 05:44 PM
JDMs1eeper's Avatar
I rewired and hooked it up just like it says to on MSD. still no start...
BUMP need help
Old Dec 2, 2003 | 05:55 PM
D-Man's Avatar
You try this to test the box? maybe its fried..
If you are using the White wire (points or electronic amplifier) of the MSD to trigger the ignition, follow these steps.
1. Make sure the ignition switch is in the Off position.
2. Remove the coil wire from the distributor cap and position the terminal so it is approximately 1/2" from a good ground.
3. Disconnect the MSD White wire from the distributor points or the ignition amplifier.
4. Turn the ignition to the On position. DO NOT CRANK THE ENGINE.
5. Tap the White wire to ground several times. Each time the wire is pulled away from ground a spark should jump from the coil wire to ground. If spark is present, the ignition is working properly.
If there is no spark:
A. Inspect all of the wiring.
B. Substitute another coil and test again. If there is now spark, the coil is at fault.
C. If there is still no spark, check to make sure there is 12 volts on the small Red wire from the MSD when the key is in the On position. If 12 volts are not present, find another 12 volt source and repeat the test.
D. After inspecting the test procedures and inspecting all of the wiring, there is still no spark, the Ignition is at fault. See the Warranty and Service Page for Information.
Old Dec 2, 2003 | 06:48 PM
salbaje's Avatar
buy an external coil.
Old Dec 2, 2003 | 07:50 PM
_Endless_'s Avatar
if you're sure that you installed the MSD correctly, check the ignition fuse under the dashboard. i had similar experienced on my 6A before and i'm sure i did the wiring correctly and it turns out i had a blown ignition fuse under the dash and i don't know what caused it so i just replaced the fuse and didn't have any problem anymore.
fsg231
Apr 11, 2010 02:10 PM
Rodzknight
Jul 3, 2006 01:02 PM
smash fascism
Jul 4, 2005 10:01 PM
juicedh22
Oct 9, 2004 05:45 AM
B_1_8_hatch
Nov 28, 2003 08:28 PM
