b18c5 vtec problems
Old Jan 13, 2006 | 07:02 AM
JDM-MONKEY's Avatar
Default b18c5 vtec problems
ok heres wats goin on i got a b18c5 in my 95 ej and it runs great i had a code 10 untill yesterday but now no CEL. yet i have no vtec . ive swaped my vtec selenoid and my computer with my friends and nothing it still wont pop we grounded the selenoid better and nothing .....just installed oil pressure guage oil pressure is fine so i dont kno wat else to look for or fix.... its to the point that im completly lost ........anyone have an idea of wat it could be??????????
Old Jan 13, 2006 | 07:13 AM
len's Avatar
len
Default Re: b18c5 vtec problems (!!ej(4 dem boyz)type-r!!)
Not to sound like an ******* or anything, but those are VTEC ECUs correct?
Old Jan 13, 2006 | 07:18 AM
JDM-MONKEY's Avatar
Default Re: b18c5 vtec problems (len)
yes of coarse mines is p28 and my friends is a gsr ecu!!
Old Jan 13, 2006 | 07:27 AM
len's Avatar
len
Check the wire from ECM to the VTEC Solenoid.
Check the VTEC Solenoid's Oil Pressure Switch.
Old Jan 13, 2006 | 09:48 AM
92TypeR's Avatar
FSAE
Check continuity between the ECU harness and the VTEC solenoid and VTEC oil pressure switch using a voltmeter.
Old Jan 13, 2006 | 10:19 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: b18c5 vtec problems (92TypeR)
Is the wiring correct? Is VTEC ran from the ecu to the engine harness? What trim level ej do you have? If you are using the C5 harness, and putting it into a 95 civic dx, you still need to run a couple of wires from the ecu to the engine harness.
Make your next response count, you can only have 5 posts a day.
Old Jan 13, 2006 | 10:21 AM
JDM-MONKEY's Avatar
ok the oil pressure switch is fine i also changed it yesterday ..... i have to check for continiuity ...... Another thing i just noticed on my car is that were the #1 spark plug is there is alot of oil wat could that be??would that have anything to do with the vtec not working??
Old Jan 13, 2006 | 10:22 AM
JDM-MONKEY's Avatar
Default Re: b18c5 vtec problems (walker111)
its an obd2 harness and i have a 95 ex
Old Jan 13, 2006 | 10:27 AM
cool guy name
So I take it you are using a jumper harness? Oil at the end of the plug? Like in the combustion chamber or where the wire plug onto it? That wouldnt cause VTEC not to work, unless you are too low on oil.
Old Jan 14, 2006 | 10:10 AM
JDM-MONKEY's Avatar
ok last night i fixed the prob the vtec wiring was not correct then i hit vtec 1st aND 2ND gear and my car shuts off when i stop try to turn it on n nothing ..... i check for CEL it was throwing a 21 and a 3 witch i think is vtec switch and map sensor .........i was messin wit the wires this morning and now no check engine its like it throws those codes at will or somethin???any ideas????
evsproject94
Jun 9, 2005 01:51 PM
evsproject94
Jun 6, 2005 02:01 PM
Gonzo_SiR
Apr 12, 2004 08:28 PM
AdamITR
Apr 17, 2003 03:00 PM
AdamITR
Apr 14, 2003 04:38 PM
