HELP...GSR Dash in EG
Old Oct 17, 2003 | 05:03 PM
yor2slo's Avatar
Default HELP...GSR Dash in EG
Okay, I am in the process of coverting my eg interior to Integra. I was told that everything would fit, but with minor cutting on the sides(whatever that meant). I tried puting the dash in and it looks as if there is no way the cluster and componets will fit around the stock steering enforcement and brackets. If I cut the dash, It will fit, but the cluster won't. I obviously can't cut the cluster. Is there any way around this. What needs to be cut to make it all fit???
Old Oct 17, 2003 | 08:04 PM
SiHatchTurbo's Avatar
Default Re: HELP...GSR Dash in EG (yor2slo)
your gonna heed to cut the whole back of the gauge cluster part all the plastic.... and then you got to cut a little bit on the passenger side
Old Oct 18, 2003 | 06:39 AM
slowdx's Avatar
https://honda-tech.com/zerothread?id=504396
https://honda-tech.com/zerothread?id=285567
https://honda-tech.com/zerothread?id=170977
https://honda-tech.com/zerothread?id=458450
http://patriot.net/~merritt/tech.html
https://honda-tech.com/zerothread?id=486442
https://honda-tech.com/zerothread?id=411500
https://honda-tech.com/zerothread?id=401025
https://honda-tech.com/zerothread?id=184743
https://honda-tech.com/zerothread?id=139148
https://honda-tech.com/zerothread?id=94431
https://honda-tech.com/zerothread?id=553146
streetracerof06
Jun 26, 2006 06:02 PM
ted
May 26, 2005 01:38 PM
Jmorin
Jan 20, 2004 04:31 PM
yor2slo
16
Oct 21, 2003 07:54 AM
emmo
Feb 24, 2003 07:27 AM
