help with engine light
my car keeps giving me a code 14 which is the iacv so i changed it and it still throws the code. i checked the wiring still pops up and i reset the ecu so now im out of ideas the only thing that might be the problem is i have a stripped screw on my intake manifold would that throw the code???? any ideas???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0tsihatch »</TD></TR><TR><TD CLASS="quote">... i checked the wiring...</TD></TR></TABLE>How did you check the wiring? Did you just look at the plug or did you verify power & continuity back to the ECU?
That's only the first step in checking the wiring. You probably have to get a multi-meter & a circuit drawing in order to get much farther. Could be a cut wire somewhere on the way back to the ECU. Those can be a real PITA to find.
if ur runing obd2-1 and ur car doesn t idle up then back down when warm ur iac valve it not wire rite and u need to repin it
i have the wireing
but if it does we need to look more into it
i have the wireing
no but it affects it
do this put ur obd2 ecu back in if the rpm goes up and down repeatly then we need to reroute ur iac wire.
did u cut the three wire iac plug and use two wire only 4 the obd1 iac valve?
if so all we need to do is repin it
yep u have to repin it
u will need a muti-meter to find out what wire is what 4 this
actually i ll look at an obd2 car i repin tommorrow and send u the exact wires and pins to put them
civicb1812345
17
Aug 21, 2013 09:37 PM
