Transmission gone opposite
Last night I decided to drive and my tranny was shifting fine until a stop sign. I tried putting the car into first and it did but I seemed like my clutch didn't clutch and the rpms shot up like I was in neutral. I towed it back to my house and decided to bleed the system, it didn't work ( I didn't think it needed bleeding because my pedal wasn't all to squishy ). Didn't work... Now it's on my driveway and won't move, but it shifts through the gears (haven't tried Reverse) without me pressing the clutch in, but when I do press in the clutch it wont go through gears at all, it will stay stuck in neutral and act like I'm no depressing the clutch in (it's like the clutch is working in a reverse). But if I shift into a gear without depressing the clutch (since it will allow me for some odd reason now) and then press the clutch down I get a slight grind.. =[ What could be the problem? I never had this happen to me..
Re: Transmission gone opposite
Have a buddy sit in the car and pres the clutch a few times while you're outside the car and look at the clutch fork and see if it is moving and how far it's moving.
well, i popped it into reverse... and reverse gear works...
and when i did this, all my drive gears work now...
WTF?!?!?!? I'm lost now... i Don't know what cause this
Slave or master clutch. As I recall the brake line runs through the clutch line perpendicularly, maybe the depression of the pedal now pressurizes clutch plate. A valve inside the cylindar may have be inversed somehow. This is an odd one.
yeah everything was moving right, it's driving completely normal now. except for last night when i popped into 4th gear the clutch pedal stayed down so i just downshifted to 3rd then back to 4th and it worked...
