Tranny issues
Old Jun 28, 2008 | 08:03 PM
egpwns's Avatar
Default Tranny issues
problem resolved
thanks
Modified by egpwns at 1:10 PM 7/4/2008
Old Jun 29, 2008 | 05:53 AM
egpwns's Avatar
Default Re: Tranny issues (egpwns)
Old Jun 29, 2008 | 07:52 PM
Bense's Avatar
try adjusting the clutch pedal
Old Jun 29, 2008 | 08:05 PM
IN VTEC's Avatar
Default Re: (Bense)
I've had to do that once before. It was on a 2003 Accord K24. I just replaced the stock clutch with some aftermarket clutch for a college kid and it wouldn't go into gear with the engine on. It would only start to engage the synchro and cause the car to creep forward, otherwise, it didn't want to go fully into gear with the engine on.
We called a tow truck and the wrecker says, "have you tried adjusting the clutch peda?" We try it and it magically solved the problem. All in a day's work.
Old Jun 30, 2008 | 09:28 AM
egpwns's Avatar
Default Re: (IN VTEC)
I replaced the clutch master cylinder and still the same.
I have not adjusted the clutch pedal but will do this today.
thanks for the replies
Old Jul 2, 2008 | 06:28 AM
egpwns's Avatar
Default Re: (egpwns)
I changed the cmc and asjusted the pedal and still no good.
The pedal is firmer and has no play but it does the same.
needlethread
Feb 12, 2018 07:42 PM
luvinthelude
May 29, 2013 12:57 PM
MugenGTR
Jan 29, 2012 02:14 PM
BlackLudeSR
Jul 4, 2007 04:51 PM
luis666
Aug 15, 2006 01:59 PM
