Help! Car is acting weird.
Old May 1, 2005 | 01:15 PM
B18B EK's Avatar
Default Help! Car is acting weird.
Since I got my engine built I can't get it to run right. I have everything set like stock right now- Injectors, ecu, everything, but for some reason the car runs way rich and if you give it any throttle it falls. I can't find out what is wrong. No codes are being thrown and I would like to get this thing back on the road some day. A list of anything that may contribute to this would be helpful.
Old May 1, 2005 | 02:15 PM
Canuk_SiR's Avatar
Default Re: Help! Car is acting weird. (B18B EK)
looks like I have the same problem as you right now
https://honda-tech.com/zerothread?id=1230150
With mine, I've gone through everything, engine timing, wiring, etc. it all checks out.
When you pull the plugs, are they soaked with fuel? mine are
Old May 2, 2005 | 01:15 PM
B18B EK's Avatar
Default Re: Help! Car is acting weird. (Canuk_SiR)
The car runs, it just doesn't run right. It sounds like it's running right, but it isn't. It starts up with the first turn of the key, so I have no idea what it could be.
Old May 3, 2005 | 03:11 PM
95lstegman's Avatar
check your engine timing. check it GOOD. make sure the line up PERFECTLY. sometimes it can be tricky. turn the motor over 8-10 times once you have the tensioner tight. if it looks a little off after 10 times, try again, you didn't do it right. this part can be very tricky sometimes.
Old May 9, 2005 | 09:06 AM
B18B EK's Avatar
Default Re: Help! Car is acting weird. (95lstegman)
Yeah, I have done that.
Old May 14, 2005 | 04:18 PM
B18B EK's Avatar
Bump.
Old May 14, 2005 | 05:26 PM
DeadVet's Avatar
Jeff, adam said you have tried different ecus right? What else have you swapped out? Injectors? dizzy? Map sensor? Try unplugging something like the map sensor and see if it throws a code.....try to eliminate it being the ecu.
Old May 19, 2005 | 08:56 AM
B18B EK's Avatar
Default Re: Help! Car is acting weird. (1TurboHatch)
It's not the ecu, I have used Adam's and he has used mine. Codes do get thrown when you unplug sensors. I have changed the injectors, but not a distributor, if someone has one let's try it.
Old Jun 11, 2005 | 07:52 AM
B18B EK's Avatar
I just got a fuel pressure gauge and the fuel pressure is right, so I really have no idea what it could be. Someone must have some idea what it could be.
Old Jun 11, 2005 | 08:57 AM
HoUTX98GSR's Avatar
leaky injector?
i had the same problem on my old da.
injectors is about the only think i didnt check
Old Jun 12, 2005 | 07:52 AM
B18B EK's Avatar
Default Re: Help! Car is acting weird. (HoUTX98GSR)
I have used two different sets of injectors, unless it might be something with the fuel rail. Could that be it?
Old Jun 12, 2005 | 05:21 PM
HoUTX98GSR's Avatar
i doubt it....... FPR????
Old Jun 14, 2005 | 10:10 AM
B18B EK's Avatar
I have swapped that also, but if the fuel pressure is correct then wouldn't the fpr be operating correctly? I am using the same head from when I melted a piston, could the head be bad? It looked fine, but maybe something got messed up. I dunno.
Old Jun 15, 2005 | 10:18 AM
B18B EK's Avatar
I don't think it's ignition related because it starts up on the first crank, but what might I check for in the ignition?
Old Jun 15, 2005 | 12:03 PM
ramtyper19's Avatar
I had a problem like that turned out the map and TPS were plugged up wrong.
Map in TPS and TPS in MAP
Old Jun 17, 2005 | 05:00 PM
B18B EK's Avatar
Default Re: Help! Car is acting weird. (ramtyper19)
And it didn't set off any codes?
Old Jun 19, 2005 | 05:41 PM
ramtyper19's Avatar
oh yea it did..
But I always had a CEL (o2 sensor) so I over looked it...
Quick question, do you have a cat on the car could it be blocked..
My car one day out of the blue blocked up the cat... would give it gas and it falls
also no CEL
krayzieboi213
May 27, 2008 09:46 PM
gt35rSI
Nov 15, 2007 01:47 PM
mongoliandonuts
Jul 15, 2004 03:05 PM
Qikcivic
Jul 29, 2003 07:07 AM
speedaccordinly24
May 11, 2003 11:12 AM
