Help!!!Clutch master cylinder!!!
Old Jan 21, 2008 | 07:11 PM
juniestyle's Avatar
Default Help!!!Clutch master cylinder!!!
Last week the clutch was all the way on the floor...so i checked the master cylinder and what do you know...there is no fluid what so ever...so i put some brake fluid and bled the brakes...so, so far so good...then today it was all the way to the floor again...so i check the maskter cylinder again and no fluid...so i redid what i did last week... and this time i checked for leaks...NO LEAKS...or i cant find it...what problems can i have...or what should i check??? HELP PLEASE!!!
Old Jan 21, 2008 | 08:29 PM
dcRay's Avatar
Default Re: Help!!!Clutch master cylinder!!! (juniestyle)
Did you check the firewall from the inside where the clutch pedal attaches to the master cylinder?
Old Jan 21, 2008 | 08:43 PM
SkimN's Avatar
fill it with fluid, drive it a few miles, then pop the hood and start at the clutch master cylinder, follow the line till you get to the clutch slave on the transmission.
did you find the leak?
you'll probally need replace clutch master cylinder and clutch slave
Old Jan 25, 2008 | 02:31 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juniestyle &raquo;</TD></TR><TR><TD CLASS="quote">so i check the maskter cylinder again and no fluid...so i redid what i did last week... and this time i checked for leaks...NO LEAKS...or i cant find it...what problems can i have...or what should i check??? HELP PLEASE!!! </TD></TR></TABLE>
it's gotta be going somewhere. check in front of the tranny at the slave cylinder.
JDMswagSerf
Dec 10, 2013 09:47 PM
the_dxB16
Nov 30, 2008 12:51 PM
-Championship-
Apr 8, 2007 01:06 PM
714JDMBB4
Aug 29, 2005 05:34 PM
TurblowR
Mar 28, 2005 06:26 PM
