Heater line block off
On a b-series head, you can use a rocker arm plug, its the same thread pitch and diameter.
The part is # 1
and the part # is 12208-PR3-000 , $3.14
As far as the rear, like stated, use a cap off plug w/ a clamp.
The part is # 1
I capped them off with 5/8" part store caps. A word of advice: the generic rubber caps seem to slightly start cracking after a couple of months--not enough to leak but I bet eventually the cracking would get deep enough to spring a leak. I have a cap on one of the ports marked EPDM on the outside. I am assuming the cap is made of EPDM which is a type of synthetic rubber--the one marked EPDM has no cracks whatsoever after over a year of use so try to look for those. The ones with no markings are garbage and will start cracking after a few months. Also, to the person who said it will overheat--all the heating system is is and exterior loop, it is not integral to the performance of the motor. Drag racers and gt-4 and gt-5 road racers (which run long and hard enough to prove if it was problematic to cooling which has proven to not be) have been running caps or welded off ports for years and it is pretty proven to not effect running temperature. The only thing I could maybe see effecting running temp is the fact that your "second radiator" is gone (heater core) which will be the same weather you are capping off the lines or connecting them with a loop....When I first took out my heating/vent system I originally looped the conncectors together but I wanted to clean up the engine compartment so I capped them off--I haven't noticed any temp. difference between the two methods. If you are going to cap just remember to look for caps marked EPDM.
