Coolant experts needed. Coolant line Q.
Old Jan 21, 2004 | 11:52 AM
notstock93's Avatar
Default Coolant experts needed. Coolant line Q.
I have a swap thats nearly done, but im running into problems trying to find out where the coolant lines go. This motor uses a B16A2 block with an OBD-I B18C1 head with stock everything. The water piping on the back of the block is from my old LS motor (the GSR one has a line capped off, and I didnt know if I needed it)
I have most coolant lines hooked up, but I need to know where the line goes that runs out of the back of the block on the left side up near the head. If someone could draw me a diagram of where the lines need to go, I would pay them. This requires research on their part, of course, but its an easy way to make 20 bucks.
Everyday im without a car is a day that I have to bum a ride to my classes.
Old Jan 21, 2004 | 12:06 PM
Team 4R's Avatar
Default Re: Coolant experts needed. Coolant line Q. (notstock93)
take a picture..........
Old Jan 21, 2004 | 12:35 PM
notstock93's Avatar
Default Re: Coolant experts needed. Coolant line Q. (Team 4R)
ill take a picture tonight, ill be at work untill 9, so if someone wants to draw a clear diagram of coolant paths from the block to the head, the offer of 20 bucks still stands. It would be paypal, BTW.
Old Jan 21, 2004 | 12:40 PM
92civeg's Avatar
edit: im an idiot
Old Jan 21, 2004 | 12:42 PM
notstock93's Avatar
Default Re: Coolant experts needed. Coolant line Q. (92civeg)
that looks to be a vacuum line diagram....and not for B18C1 to boot.
Old Jan 21, 2004 | 02:06 PM
notstock93's Avatar
up for an easy 20 bucks.
Old Jan 21, 2004 | 05:08 PM
notstock93's Avatar
Offer is suspended while I try out one persons diagram. If it doesnt work, the offer is back on the table.
Old Jan 21, 2004 | 06:14 PM
acy76's Avatar
Have you checked the Helms for the GSR yet? The 94 Helms is available here: http://icelord.net/honda/repair/
If you're on dialup, i can probably email you the relevant pages. Let me know.
Old Jan 21, 2004 | 08:51 PM
notstock93's Avatar
Default Re: Coolant experts needed. Coolant line Q. (acy76)
if you want to e-mail the relevent pages, please do. Imayellowrobot@yahoo.com.
also, what the hell is the sensor that has two vaccum lines going to it on the left side of the manifold above the throttle body? not the map, its a black sensor attached to the mani itself. Mines not hooked up, and I dont see any plugs hanging free. If you want to send me the wiring/sensor sheets, id be very gratful. Also, I would count this as the correct diagram, so you win the race for 20 bucks as well. If its the correct diagram, of course.
Old Jan 21, 2004 | 10:00 PM
hondatim's Avatar
That 'sensor' is not actually a sensor. It is the canister purge valve. If you still can't figure out your coolant hose situation, let me know with a PM.
Remember, we're in KC also...
Old Jan 22, 2004 | 06:07 PM
acy76's Avatar
Still in need of that Helms stuff? Or did you get your answers already? [I don't care about the 20 bucks, just trying to help...]
Old Jan 22, 2004 | 07:06 PM
notstock93's Avatar
well, I think I got everything sorted out. If you could send the helms diagram for the vacuum lines and for the coolant lines, id be in your debt big time.
Old Jan 22, 2004 | 07:33 PM
acy76's Avatar
Check your email.. sent over about 10 pages of Helms stuff. Let me know if its what you need.
Old Jan 22, 2004 | 07:54 PM
notstock93's Avatar
I got em, but my computer is not recognizing the file format. I must not have the same program you used to view them.
Old Jan 22, 2004 | 07:58 PM
acy76's Avatar
You'll need to use WinZip to extract the split zip files (must be in same directory). I used Acrobat 6.0 to create the PDF, so you may need reader v6.0 (free download from Adobe) to view it. Any other questions, email me.
Old Jan 22, 2004 | 08:01 PM
notstock93's Avatar
hmmm, I have adobe 6, but I dont have winzip. Ill get winzip and then get in touch with you to get them again. this is gonna be cool.
B18 CYA
Aug 29, 2006 06:48 AM
turbotime
Nov 5, 2005 12:34 AM
Darkteg
Oct 25, 2002 09:00 AM
