Heated O2 Sensor Question
Old May 19, 2003 | 06:33 AM
7rrivera7's Avatar
Default Heated O2 Sensor Question
I was running an OEM Manifold on my B16a/CRX which used a one wire O2 sensor. I recently installed a header and had to extend the sensor wire to reach the O2 bung on the collector. Now my A/F meter doesn't react unless I'm driving 'spiritly'. I'm assuming it's because the temperature at the collector isn't warm enough to activate the sensor.
I'd like to install a heated O2 sensor but it has 4 wires. Can someone describe the use of each wire so I can connect it properly?
Thanks!
Old May 19, 2003 | 09:59 AM
dfoxengr's Avatar
Default Re: Heated O2 Sensor Question (7rrivera7)
yes its because of heat.
take the 4wire, white to signal, stock 1 wire (wire)
either black and the green to ground, and other black to switched (ignition) power.
thats all.
Old May 19, 2003 | 10:08 AM
7rrivera7's Avatar
Default Re: Heated O2 Sensor Question (hybridvteceg)
Will a three wire work also? I've been told black to signal, both whites to +12v. Sensor is grounded by the header
Old May 19, 2003 | 10:10 AM
dfoxengr's Avatar
i wouldnt think so. but try it. just buy a used 4 wire for like 30-40
bam69icp
Oct 21, 2008 08:35 PM
bmheck5184
Jul 29, 2005 05:20 AM
Slow96RedEk
May 16, 2003 08:10 PM
