Cam caps out of order. Problem?
Old May 18, 2003 | 07:25 PM
ChiBoy's Avatar
Default Cam caps out of order. Problem?
If someone removes cams, is it possible to get the cam caps out of order? Like if they don't mark where they came from and then mix them up.
If so, how do you fix it? Are the caps marked for position?
Old May 18, 2003 | 08:30 PM
J2turbo21's Avatar
Default Re: Cam caps out of order. Problem? (ChiBoy)
There should be some numbers on them and arrows pointing in the correct direction.
Old May 18, 2003 | 08:39 PM
Ivan's Avatar
senior gold member
Default Re: Cam caps out of order. Problem? (J2turbo21)
yup and the arrow is suppose to point towards the timing belt.
Old May 18, 2003 | 08:42 PM
b19coupe's Avatar
Default Re: Cam caps out of order. Problem? (Ivan)
And they have "I" and "E" stamped on them.
Old May 19, 2003 | 10:11 AM
ChiBoy's Avatar
Thanks for the help guys! That's just the info I needed.
1984eghatch
Jun 8, 2012 12:01 AM
guedo148
Jul 30, 2007 08:05 PM
BumpinVTEC
Feb 28, 2005 04:46 AM
216.226.142.95:27016
Jun 27, 2003 10:22 PM
