Head Gasket
Old May 26, 2003 | 01:34 PM
redintheface's Avatar
Default Head Gasket
Just wanted to know how hard it would be to change a head gasket on a B18c1. Also i have oil leaking out from the left side near the headers where the block and the head come togeather there is like a litle vin number there too if that helps . Would that be because my head gasket is shot .
Old May 26, 2003 | 01:41 PM
.RJ's Avatar
.RJ
Default Re: Head Gasket (redintheface)
probably teh cam cover gasket dripping down
Old May 26, 2003 | 02:00 PM
Default Re: Head Gasket (.RJ)
all ready checked that its tight and no oil leaking from there .
Old May 26, 2003 | 02:04 PM
.RJ's Avatar
.RJ
did you replace it?
Old May 26, 2003 | 02:45 PM
IN VTEC's Avatar
Check the distributor-side exhaust cam seal.
A head gasket replacement only takes about 5 hours, but it'll save you 4.5 hours if you only have to replace the cam seal.
Old May 26, 2003 | 03:12 PM
Default Re: Head Gasket (IN VTEC)
its not the cam seal its leaking from inbetwene the head and the block . let me see if i can get some pics up .
Old May 26, 2003 | 03:14 PM
.RJ's Avatar
.RJ
many times the oil will drip down onto the headgasket from the cam seal or valve cover gasket, and will appear that the headgasket is leaking
Old May 26, 2003 | 03:29 PM
ok i'm going to take it the place that out the motor in for me and see what they say about it . I was just woundering what felow HTers thought it was . I'll let you know what they say .
Old May 26, 2003 | 06:09 PM
Jimmy's Avatar
Global Moderator
man that same **** happen to me....
i thought my head gasket was bad and my boy shawn (22lbgs-r)
took my distributor off and greased the seal on the back of it and it stopped.
Notes: thought my head gasket was shot and it wasnt.
it turned out to be a seal on the back of the distributor
Old May 26, 2003 | 06:20 PM
Patch's Avatar
Default Re: Head Gasket (USDMDC2)
Spray that whole area down with a buttload of brake cleaner, then go run the **** out of it. Come back, pop your hood, and see where its coming from. Its probably not your head gasket.
Old May 27, 2003 | 10:40 AM
95hbMatt's Avatar
Default Re: Head Gasket (CRX PAT)
sup kenny, any word? did you find out the prob?
BertDog
Mar 12, 2012 07:19 AM
si_freak
Aug 22, 2009 07:41 PM
UNDER PRESSURE
Oct 6, 2003 08:37 AM
Blanket Jackson
Sep 12, 2003 09:43 PM
12secB18acivic
Nov 24, 2002 10:58 PM
