oil leaking between head and block!
Old Nov 19, 2002 | 04:05 PM
12secB18acivic's Avatar
Default oil leaking between head and block!
its a ls motor and oil is leaking out between head and block. I'm sure its coming out of there and not from the cam seal or anything else. its leaking from the cam gear side. is it a Bad head gasket? someone told me that it could be a bad oil pin? what is that? never heard of a oil pin! please help
Old Nov 19, 2002 | 06:04 PM
NA EJ1's Avatar
Default Re: oil leaking between head and block! (allmotorcivic)
if its where your saying its from, then you do have a blown headgasket...you can also try the valve cover gasket too...alot eaiser to change
Old Nov 19, 2002 | 06:08 PM
poison's Avatar
Default Re: oil leaking between head and block! (CC94B18)
I also agree with this statement
you might as well purchase a gasket kit to replace 'em all.
Old Nov 19, 2002 | 08:03 PM
Fuuma0083's Avatar
Default Re: oil leaking between head and block! (poison)
if its where your saying its from, then you do have a blown headgasket...you can also try the valve cover gasket too...alot eaiser to changeI also agree with this statement
double agree
Old Nov 20, 2002 | 02:48 PM
Default Re: oil leaking between head and block! (Fuuma0083)
up
Old Nov 20, 2002 | 02:56 PM
can the blown head gasket cause white smoke from the exhuast?
Old Nov 20, 2002 | 03:03 PM
Chiovnidca's Avatar
Yes.
Old Nov 20, 2002 | 05:24 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: oil leaking between head and block! (Chiovnidca)
Yes, it can cause white smoke. Check for oil in your coolant as well. Do you have a leakdown tester? Sometimes you can localize the leak with that.
As the others said, if you're up to it, get the Honda gasket kit and do the work. If I remember correctly, it was $270 or something.
Old Nov 20, 2002 | 06:12 PM
Default Re: oil leaking between head and block! (shamoo)
what is a leak down tester? and what will that tell me?
Old Nov 20, 2002 | 07:06 PM
RenoRacing's Avatar
it will tell you weather it's your headgasket , or your valvecover gasket
Old Nov 20, 2002 | 07:11 PM
Doogie Howser's Avatar
Default Re: oil leaking between head and block! (HavokRacing)
are there bubbles in your coolant, also if you up for an oil change, drain it and check if its milky
Old Nov 21, 2002 | 03:44 PM
Default Re: oil leaking between head and block! (mlambrecht)
thanks everyone for the input I am going to change the gasket this weekend how many psi to torque the head down?62 rite?will i need to resurface the head?
Old Nov 21, 2002 | 04:04 PM
im not exactlly sure on wat to torque the head but no you wont need to resurface the head, while your taking it off id consider doing a waterpump and timing belt if your due soon
Old Nov 21, 2002 | 04:52 PM
Chiovnidca's Avatar
You'll ned to check it with a straight edge to determine that.
Old Nov 22, 2002 | 04:47 PM
now i just took off my headers and the exhaust port seem to be oily. is this cause by the blown head gasket? or is it bad valve seals?
Old Nov 24, 2002 | 10:58 PM
jay99EK's Avatar
how oily is it?? the connections should hav a light oil on them.. that's normal~ and the insides of the headers could have a light oil as well~
if there is oil on the outsides of the headers then that's abnormal~
from what you've been saying.. it sounds like a bad head gasket~ is there white smoke coming out of your tail pipe?? that COULD be it.. that's what i'm guessing~
as for the "bad oil pin" iono wtf that means~
93grayeg
Sep 24, 2018 03:46 PM
si_freak
Aug 22, 2009 07:41 PM
redintheface
May 27, 2003 10:40 AM
