H22a swapped rebuilt engine wiring problem
Okay guys please can you help me on this i have everything hooked up but i think i have something hooked up wrong because when i put the battery in and connect it the engine starts turning over automatically when there is no kegs in the ignition what could it be please help me
Yup switched starter and it stopped doing that got a new problem now. Im getting no spark dizzy checks out within spec traced all wires back to ecu all have continuity what could make the ecu not send the signal to the dizzy to not spark? A fuse? Main relay? Cranks but zero spark
What distributor are you using? I am running an OBD1 H22a1 external coil distributor distributor on my H22A with no issue. No spark at all I would follow the distributor harness make sure the plug to the distributor is plugged all the way in first then follow wires and check fuses
I figured it out guys!!!! It was a 15amp fuse under the dash pannel that wasnt even there put a new one in sprayed some starting fluid in and she fired right up!!!!
Stoich EG2
Dec 15, 2004 06:35 AM
SpeedMonkeyRacing
21
Oct 29, 2002 12:51 PM
