sohc problems motor won't start
My motor doesn't get any spark . engine turns over just doesn't start . I have replaced distributor, replace main assembly relay, fuses, and reset ecu. Please HELP!!
Re: sohc problems motor won't start
are you getting spark at the cap or nowhere?
you might have gotten a bad distributor
some salvage yards in my area will do a 15 day warranty...
I'm not getting any spark at all I tested the spark plug and wires and nothing but I have tried to install 2 distributors that worked and still nothing
so your tested the plug and the wires
but did you test for spark at the distributor?
take the wires off and check if your getting spark at the distributor
Do you have battery voltage on the BLK/YEL wire attached to the igniter unit in the distributor when the key is turned to ON(II)?
Do you have an open or short in the YEL/GRN wire that attaches to the igniter unit and runs to the ECU?
be professional
What kind of wires are they? I recommend only OEM Sumotomo or NGK. Cheap no-name parts store wires are known to pull apart internally. I've had a number of sets fall apart on me straight out of the box.
well man if you have spark at the destributor but not at the end of the wires when plugged in...
there is a short in the wires
replace them... start your car
clean95hatch
12-13-2012 09:13 AM
ejprimo
04-25-2003 10:20 AM
