h22 rear main seal (crankshaft) - help?!
Old 06-03-2010, 07:53 PM
Nathan007's Avatar
Default h22 rear main seal (crankshaft) - help?!
Hey fellas!
Well, i'm currently finishing up some work on my brother's 93 h22a, and i've run into a little issue i'd like to get some imput on.
I've installed the crankshaft rear seal (flywheel side) with the cover off, following those instructions;
I was supposed to keep 0.5 - 0.8mm between the bottom of the cover and the seal (not pushing the seal all the way in) but after many attempts (little more, little more, need some more, f*ck!!) i went right trough..
I did not want to risk damaging the seal pushing it back out so i installed it this way, following the instructions and slightly oiling the crankshaft boss and seal lip before putting the cover/seal back on. Today, after installing the timing belt and giving the engine a few turns to make sure everything works correctly, i noticed a nice pack of grease at the bottom of the rear seal;
That was the grease what was originally inside the seal, and it doesnt seem normal that it would come out like this...Most probably, it will literally **** oil, what do you guys think?
Worst case, i'll try re-installing it properly, i just hope it wont get damaged while i'm removing it. What should i expect?
Old 06-03-2010, 10:08 PM
seanbev24's Avatar
Default Re: h22 rear main seal (crankshaft) - help?!
I can't tell if those grease areas are from damage or grease just wiped onto the crank during installation. It looks to me like it's time to buy a new seal and try again. What did you use to install it?
Old 06-03-2010, 10:16 PM
nsxter's Avatar
deff time to buy a new seal and try again
Old 06-03-2010, 10:42 PM
Nathan007's Avatar
Well i guess i'll try it again with a new one, luckily i've got another laying around for my F23, same part number
I first used an old balancer belt sprocket to drive it in squarely, then a useless ford bronco oil filter to drive it in deeper (sprocket bottoms out on cover, filter is almost same diameter as seal). Yeah it's ghetto, i know!
Old 06-04-2010, 04:34 AM
Mikey3000's Avatar
put a little oil around the outside of the seal and it'll go in much easier.
Jk_DC2
02-21-2009 08:26 AM
integ401
05-24-2007 06:35 AM
1Quikgsr
12-01-2006 10:21 AM
bb4socal
11-16-2006 07:53 PM
whizdumb
01-08-2005 05:20 PM
Quick Reply: h22 rear main seal (crankshaft) - help?!
