Why put a GSR head on a B16 block?
Old Aug 18, 2002 | 12:45 AM
CBR's Avatar
CBR
Default Why put a GSR head on a B16 block?
I'm just curious.
Wouldn't you want a GSR head to be on a LS block? I can't figure out why some people buy a GSR head and put it on a B16 block.
Please explain why.
Old Aug 18, 2002 | 08:15 AM
non-VTEC's Avatar
Default Re: Why put a GSR head on a B16 block? (ChurchBoyRacer)
smaller combustion chamber, higher compression ratio.......
Old Aug 18, 2002 | 08:24 AM
salbaje's Avatar
gsr head on b16 will yield a 10:4:1 compr. ratio
Old Aug 18, 2002 | 08:29 AM
No-Gi's Avatar
Default Re: Why put a GSR head on a B16 block? (salbaje)
makes power
Old Aug 18, 2002 | 03:37 PM
3rdGteg's Avatar
Default Re: Why put a GSR head on a B16 block? (B16aEK)
what happens when u put a b16 head on a gsr block?
Old Aug 18, 2002 | 03:51 PM
Projekt20's Avatar
Default Re: Why put a GSR head on a B16 block? (3rdGteg)
It raises the CR up to about .2 .....so if stock was 10.2:1 with the head it'd be at about 10.4:1. I was gonna build one and use CTR pistons as well....but got caught up in rebuilding the B18C instead.
Old Aug 18, 2002 | 06:53 PM
acuratech's Avatar
Default Re: Why put a GSR head on a B16 block? (Projekt20)
i have a gsr head for sale if anyones interested
Old Aug 18, 2002 | 09:34 PM
r7's Avatar
r7
Default Re: Why put a GSR head on a B16 block? (acuratech)
Old Aug 18, 2002 | 10:16 PM
blkDOHCsol's Avatar
New User
Default Re: Why put a GSR head on a B16 block? (r7)
wouldnt the b16 head flow better?
Old Aug 18, 2002 | 10:22 PM
B18C-EJ1
Guest
Posts: n/a
Lowers compression.
Old Aug 18, 2002 | 10:24 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Why put a GSR head on a B16 block? (blkDOHCsol)
I've been told by many head porters, that the GSR in factory trim flows better than the B16. It's only when you start to port & polish the head, that the B16 shows it's true colors.
The difference between the 2 are minimal at best when opened up. It's just a matter of preference, and options such as ITR manifold vs. Skunk2 unit.
Also, when you use the Skunk2 ITR/GSR manifold, the angles are all wrong, and the flow is not as smooth as a ITR manifold on a B16A engine.
Old Aug 19, 2002 | 07:18 AM
X2BOARD's Avatar
Default Re: Why put a GSR head on a B16 block? (B18C-EJ1)
Gotta match port the GSR head to the ITR/skink mani to get the best gains.
MMMmmm... GSR head on B16 block... Near perfect R/S, great top end, better low end tq (dual stage), lower vtec enagagement (need GSR ecu and vac lines) Why NOT do this ?
maxheat
24
Feb 26, 2005 12:36 PM
BI8B
Sep 11, 2003 08:38 AM
.ShawnD.
21
Jul 17, 2003 08:15 PM
Tyson Ballou
Dec 26, 2001 06:17 PM
