good compression ratio
Old Mar 23, 2011 | 06:11 PM
down_the_hatch's Avatar
Default good compression ratio
I plan on building a poor man type-r engine soon. I've been messing with the compression calculator and I am looking at around 11 for the CR.
What's a good CR for street use? passing smog? pump gas?
any info is great from the Honda Gods ..... none of that BS talk
thanks again guys
Old Mar 26, 2011 | 05:05 AM
hondam's Avatar
Default Re: good compression ratio
what block and head are you using? a simple way to good poor man type r is a gsr block and a b16 head, you still be around 10 CR, which could pass smog.
11 CR you get when using pr3 piston on a ls block or civic type r piston (12 CR)
Handel Spencer
K Series
Jun 5, 2019 02:40 PM
JDMoMo
Oct 28, 2011 02:46 PM
rorik
Oct 16, 2005 02:46 PM
othick
Apr 2, 2003 04:32 PM
