taking head off block... is it hard...?
Old Nov 2, 2003 | 08:06 PM
Gonzo_SiR's Avatar
Default taking head off block... is it hard...?
I have the engine on an engine stand...
How tight are those Head bolts...?
Will I be able to do it by myself....?
Old Nov 2, 2003 | 08:19 PM
Kendall's Avatar
Get a big ratchet or breaker barand a piece of steel pipe a couple of feet long. Insert the handle of the ratchet/breaker bar into the pipe. and loosen the head bolts holding the end of the pipe. Remember that the longer the handle, the more torque you have and the easier it is to remove pain in the rear bolts like head bolts. Have fun.
Old Nov 2, 2003 | 08:47 PM
maxxdout's Avatar
Default Re: (dc231)
if ytou dont have access to air tools you will need to secure the engine stand or you will be walking it all over the shop. Also, get instructions to be sure there isnt a removal order to safeguard aginst warpage..
Old Nov 2, 2003 | 09:27 PM
That Dood's Avatar
Default Re: (dc231)
undo the headbolts bolts 1/3 turn at a time. there is an order. You dont need a breaker bar ubnless your some little 140 lb dood. good luck
Old Nov 3, 2003 | 06:00 AM
maxxdout's Avatar
Default Re: (That Dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by That Dood &raquo;</TD></TR><TR><TD CLASS="quote">undo the headbolts bolts 1/3 turn at a time. there is an order. You dont need a breaker bar ubnless your some little 140 lb dood. good luck</TD></TR></TABLE>
&lt;~~~~~~138lbs 5'6", NO breaker bar needed. Speak for yourself
Old Nov 3, 2003 | 06:02 AM
Audi RS4's Avatar
Lover
Default Re: (maxxdout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout &raquo;</TD></TR><TR><TD CLASS="quote">
&lt;~~~~~~138lbs 5'6", NO breaker bar needed. Speak for yourself</TD></TR></TABLE>
small fry
make sure you get new head bolts when reassembling.
Old Nov 3, 2003 | 11:00 AM
Evs-One's Avatar
Solbros Owns Me
yeah, don't just take a impact to them.....then you'll leave only one bolt torqued down causing the head to warp most likely.
Spin the ratchet/breaker bar towards yourself and brace the stand against your body....this will support the engine and keep it from moving.
Old Nov 3, 2003 | 11:35 AM
owen_the_soyboy's Avatar
Default Re: (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get new head bolts when reassembling.</TD></TR></TABLE> well you can torque them 3 times before new ones are required.
Tong.Y
32
Feb 1, 2011 02:05 PM
christmastree
Sep 15, 2009 07:41 PM
xiaogou
Apr 7, 2007 12:47 PM
SPEED123
Nov 29, 2003 12:49 PM
smashed4thgen
Oct 20, 2002 07:08 AM
