foam from radiator
Old Jun 13, 2004 | 10:54 PM
aznprde's Avatar
Default foam from radiator
did compression check. perfect... so not suspecting any cracks/head gasket problems.
if i rev the motor small bubbles start to appear out of the neck on the radiator.
next thing i know it's foamy.
this is pushing water out of my radiator and flooding my overflow container. THEN, when the motor cools down, i'm low on water because of what was forced out and THEN i overheat.
what could be causing this? i'm stumped!
i may try a leakdown anyway?
Old Jun 14, 2004 | 02:18 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: foam from radiator (aznprde)
yes try a leakdown to be sure
Old Jun 14, 2004 | 01:59 PM
aznprde's Avatar
Default Re: foam from radiator (bruceleeroy)
assuming the leakdown doesn't show anything.. THEN WHAT??
is it POSSIBLE the leak down will show something the compression check DIDN'T?
Old Jun 15, 2004 | 04:41 PM
aznprde's Avatar
bump?
Old Jun 15, 2004 | 07:00 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
A compression test by cranking the engine over is much too fast to reveal a small leak into the water jacket. Think about it for a second. At high combustion pressures when the engine is running you are only getting small bubbles. At much lower pressures when you are only cranking the starter and no combustion is happening, you might not get anything at all. Bubbles = combustion gas coming from somewhere, so I hope it's a headgasket because everything else is worse.
Old Jun 15, 2004 | 09:41 PM
aznprde's Avatar
Default Re: foam from radiator (tjbizzo)
mother fvcking WERD. i'm praying it's a head gasket 'cause if it's a sleeve, i don't have the $$ to have it redone. if it's a water jacket .. well... we all know what that means.
anyway, i can TELL if it ONLY the headgasket??? i've been suspecting head gasket problems for some time now.
ThatsMyEG
Nov 5, 2010 05:45 PM
NubImports
Mar 18, 2009 10:09 AM
jdmkid_82
Jan 12, 2007 02:33 PM
djtony5
Oct 18, 2005 10:36 PM
Scubster
Jan 4, 2005 01:04 AM
