IACV + Loosing radiator fluid? Is it possible?
Ok i have a 95 civic pretty much a lemon. lol anyways last year i replaced the headgasket, waterpump, radiator, hoses and thermostat. a couple of months ago it started idling funny so i took the throttle body off to replace the gasket i also took the Idle Air Control Valve off when i took the IACV off i noticed on the water side it was all clogged up and corroded. I cleaned everything put it all back together started the car up and it started reving up and down, at this point i was like whatever it runs. couple of days of driving it it started over heating so i check the water it was low filled it up so on....... Well its still loosing water i thought headgasket so i did a compression test the compression is good its loosing water very slowly, i did notice there was white smoke coming out the tell pipe which is a very small amount. i was wondering if the IACV was broke would it cause water to be sucked into the engine or is it the head gasket??
Re: IACV + Loosing radiator fluid? Is it possible?
did you have the head resurface when you replaced the headgasket? Did you check for flatness on the engine block? A leak down test will tell you where you are leaking form.
Modern91Hatch
07-25-2006 05:26 PM
Modern91Hatch
06-05-2006 02:46 PM
