AN Fittings
Old Jan 27, 2009 | 06:45 PM
accord_raffi's Avatar
Default AN Fittings
Hey guys.
Ok so I was reading online and I found out on a Chevellestuff.com that AN fittings are designed not to use any sealant because of their cone locking shape. By using a sealant, you can create leaks. Instead, they recommend using a lubricating oil. Has anyone heard about this before? If it's true, maybe that's why I leak a little oil from my oil pan fitting for my oil return line.
Old Jan 27, 2009 | 06:49 PM
wbaldwin_86's Avatar
Default Re: AN Fittings
yes it is true
Old Jan 27, 2009 | 07:04 PM
locash's Avatar
Yes, AN fittings seal on the mating surface, no sealant should be used..
Old Jan 27, 2009 | 07:27 PM
ok next oil change i'm cleaning off the teflon. thanks guys. Do you suggest using oil or is that just above and beyond?
Old Jan 27, 2009 | 07:29 PM
redboost10's Avatar
a very small dab of grease is cool, especially where they are next to a huge heat source.
zexifiedlude
Apr 9, 2006 07:46 AM
LSVtechnologytur...
Sep 17, 2005 01:46 PM
DC2R714
Jul 19, 2002 05:25 AM
GruvyTune
Nov 18, 2001 03:59 PM
