Transponder question:
Old Jan 27, 2009 | 12:56 AM
kaj's Avatar
kaj
Default Transponder question:
facts i believe to be true (2000 Integra):
microchip is in the key.
transponder receiver is in the gauge cluster.
so: if i have an OBD-1 ecu, will i still need the key in order to work with the transponder?
if so: if i have an OBD-1 ecu and swap out gauge cluster, then i won't need the chipped key?
just trying to figure out which parts are dependent and, in what way, the transponder affects the starting of the vehicle.
i'll be going to an OBD-1 ecu when i tune.. and i have a really cool "type r" key, from the dealership, that i'd like to use.. but, it obviously has no chip in it.
Old Jan 27, 2009 | 09:28 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Transponder question:
Imobilizer receiver unit is attached to the ignition, little black ring with a green plug.
The flashing key on the cluster is only an indicator.
Any OBD1 ecu will start no problem. Your new key will be fine with the OBD1 ecu.
If you change to a different ecu that uses imobi, you will need to reprogram it, or find the brake code and use that to start every time.
Old Jan 27, 2009 | 10:02 PM
kaj's Avatar
kaj
perfect! sensor attached to ignition, but it's the ECU that requires the signal be read. you rock man. thank you, very much.
i thought someone told me, once, that part of the imobilizer was in the gauge cluster, so you wouldn't be able to swap them out. hm.
info noted. thanks, again.
axelintegra
Engine Management and Tuning
Aug 29, 2009 11:45 AM
NA JDM GSR
14
Jan 13, 2007 04:51 PM
dkrex001
Oct 25, 2006 02:09 PM
THE LORD OF CHAOS
Jul 5, 2005 01:34 PM
