Enigne is running like crap!
Old May 20, 2006 | 02:34 PM
b20vtechatch
Guest
Posts: n/a
Default Enigne is running like crap!
I just finnished my ls rebuild and the engine is running rough. i lined up the camshaft arrows and lines and lined the crank up to TDC. The engine started right up, but when i went to time it the timing line was way out of adjustment. I have the rotor in the dizzy pointing on cylinder number one and the inductive clamp for the timing light on spark plug wire number one. My question is why is the timing so retarded.
Old May 20, 2006 | 06:27 PM
d16vtecx's Avatar
Default Re: Enigne is running like crap! (b20vtechatch)
after you lined up the timing marks did you rotate it twice and check it again?
Old May 20, 2006 | 07:34 PM
b20vtechatch
Guest
Posts: n/a
Default Re: Enigne is running like crap! (d16vtecx)
yes
Old May 21, 2006 | 11:26 AM
b20vtechatch
Guest
Posts: n/a
anyone
Old May 22, 2006 | 01:10 PM
ekgcool's Avatar
Have you tried adjusting the dizzy? If the cams are not perfectly set to the crank then the dizzy will read incorrectly. I know you already double checked, but a tripple check may reveal something else. Be sure the slack on the t-belt is on the back side of the motor (closest to fire wall). Only a little slak should be evident.
Old May 26, 2006 | 07:53 AM
b20vtechatch
Guest
Posts: n/a
Default Re: Enigne is running like crap! (ekgcool)
i got the timing dead on now and the enigine is is still running rough. It sounds great under the hood, but when you go back to the exhaust it putts almost sounds like a WRX. i did a compresion test and its 195 or better across. Someone help me before i blow this thing up. motor is still in its break in period. 345 miles, ive following the break in process. anyone know whats going on?
2kdrift
Engine Management and Tuning
Aug 10, 2010 02:24 PM
dopefeen
Apr 25, 2007 04:59 PM
civic89si666
12
Dec 21, 2006 02:48 PM
Fighterinsnatch
Jul 11, 2006 05:36 PM
hatch_attack
Jan 30, 2005 01:01 PM
