Engine running rich, throwing Code 43 *help*
Old Feb 3, 2006 | 06:55 AM
i64X's Avatar
Default Engine running rich, throwing Code 43 *help*
D15B with a P28 ECU, CRX converted to OBD1 via Rywire harness.
The car's still running rich, which is still causing the ECU to throw code 43 and put the car in safe mode... Code 43 basically means that the car's not running right (usually rich) and the O2 sensor is reporting a condition besides stoch. If you look the error up it gives a very generic "Fuel System Malfunction" description.
Some things I've tried, resetting the ECU each time... fuel related things for obvious reasons, coolant related things because I read that if the ECU thinks the engine's cold it'll dump fuel like mad, causing the car to run rich and eventually throw Code 43.
Here are the things I've tried:
Changed O2 sensor for known good OEM one.
Changed plugs for known good ones (NGK-R).
Changed plug wires known good ones.
Changed temperature sensor for known good one.
Changed temperature gauge sending unit (wasn't working, probably unrelated).
Bled the coolant to remove air from system.
Changed FPR for a known good one.
Changed fuel injectors.
The only things I have yet to check or replace are engine grounds, a new thermostat, and a new ECU.
After that I'm out of things to try.
Anyone have any other ideas?
Old Feb 3, 2006 | 03:05 PM
jmcool's Avatar
Default Re: Engine running rich, throwing Code 43 *help* (i64X)
do you check to see if all your vacuum hoses are connected and do not have holes
Old Feb 3, 2006 | 07:02 PM
86si's Avatar
thought 43 was for the heated part of the o2 but i might be wrong.
Old Feb 3, 2006 | 07:15 PM
i64X's Avatar
Default Re: Engine running rich, throwing Code 43 *help* (jmcool)
Yep - checked the hoses and they're all fine. Everything on the intake mani is as it should be... I even put the charcoal can and the re-circ stuff back in.
Code 43 is a general fuel system error, the O2 sensor errors are single digit CEL codes.
Old Feb 5, 2006 | 07:46 AM
jmcool's Avatar
next thing could be your fuel filter
Old Feb 8, 2006 | 04:20 AM
i64X's Avatar
Replaced the thermostat with a new OEM Honda one.
Hooked up my fuel pressure gauge and tested the fuel pressure. It's dead on with the spec in the manual, so that eliminates fuel filters or pump according to the Honda repair manual.
Swapped ECU out for a different one and it still does it.
I'm just about out of ideas.
Old Feb 8, 2006 | 02:13 PM
Jmunk's Avatar
I'm willing to bet that the problem is in the wire harness conversion.
Old Feb 16, 2006 | 02:19 PM
Wafler's Avatar
Default Re: (Jmunk)
I have this exact same problem and I am stuck too.
I have no conversion harness though as my car is a EUDM Civic VTi (EG with B16A2).
My AF UEGO gauge reads mad rich beyond its scale (10ish:1) and fiddling with the throttle temporarily leans the mixture just to become way rich again. Tried changing the o2-sensor and it was fine for a day or two then CEL code 43 pops up again. Guess the o2-sensor is fubar once again...
We seriously need help before all this fuel foules our rings
Old Feb 16, 2006 | 05:56 PM
downburst's Avatar
Default Re: (Jmunk)
i had the same problem mine was after about a 45 min drive i replaced the fuel filter and the problem went away
Old Feb 16, 2006 | 09:50 PM
Wafler's Avatar
Default Re: (downburst)
The fuel filter is also changed.
However I can't see how a bad fuel filter can cause too much fuel? A bad filter would cause a lean mixture, correct?
Modified by Wafler at 4:17 PM 2/17/2006
Old Feb 17, 2006 | 08:14 AM
suspendedHatch's Avatar
Default Re: (Wafler)
I don't see any evidence that you're running rich. It's just an assumption you've made.
Check to make sure you have the correct O2 sensor and check it's wiring.
Old Feb 17, 2006 | 09:24 AM
EE_Chris's Avatar
Could it be that running a 1.6l ECU on a 1.5l engine is the cause?
Old Feb 18, 2006 | 05:43 AM
Wafler's Avatar
Default Re: (suspendedHatch)
If you replied to me, suspendedHatch, I have an AEM wideband with a gauge as I stated above. O2-sensor is wired correctly. Still stumped...
Old Feb 18, 2006 | 01:23 PM
2k.civic.si's Avatar
try another conversion harness...wouldnt be the first rywire harness ive heard about/seen that wasnt done correctly
brnyrdcmndo
Jun 1, 2005 06:37 PM
Leviata-N
Oct 8, 2004 07:01 AM
520_Motorsports
Aug 10, 2004 10:51 AM
Mr. 1582
Nov 7, 2003 03:32 PM
JSpecwest
Aug 7, 2001 10:00 AM
