Code 45
Old Nov 6, 2003 | 01:31 PM
Mr. 1582's Avatar
Default I need a help with Code 45
Code 45 how do I fix that
Modified by Mr. 1582 at 6:43 PM 11/6/2003
Old Nov 6, 2003 | 02:31 PM
Mr. 1582's Avatar
Default Re: Code 45 (Mr. 1582)
A code 45 is System Too Lean or Too Rich malfunction in the fuel monitoring systems.
What componets are in the fuel monitoring systems.
Old Nov 7, 2003 | 04:21 AM
EE_Chris's Avatar
There exists fuel trim parameters called Long Term and Short Term Fuel Trim. When the LTFT reaches its limit of +/- 20%, you will get this code. This parameter is adjusted based on O2 sensor feedback. If the O2 is showing a constantly rich mixture (or lean, for that matter), the ECU will use these fuel trims to try and get the mixture such that the O2 sensor is 'swinging' again.
So while I am NOT saying that your O2 is duffed, though it could be, you really could be running that rich/lean.
Old Nov 7, 2003 | 03:32 PM
Mr. 1582's Avatar
Default Re: Code 45 (EE_Chris)
How do I change that rich/lean conditions
civiccarbuff
Sep 18, 2008 08:29 PM
haroldthefly91crx
Aug 19, 2007 07:08 PM
91ef_ls
Nov 15, 2006 06:15 AM
brnyrdcmndo
Jun 1, 2005 06:37 PM
ScubaStevo80
Jan 24, 2003 06:26 PM
