Bent Rod? D16
Old Aug 9, 2004 | 10:02 AM
Drew Peacock's Avatar
Default Bent Rod? D16
Wondering what are the symtoms of a bent rod? I have had what I thought at first was a spun bearing but the car still go's we then showed it to a few other people and they thought it sounded like a dry ring glazed bore! This sounded probable because the car was misfiring because of to much fuel.
I gave it some gas the other day coming home and it still seems to go well, theres just a constant tapping noise increases with rev's, mechanic know thinks it could be a bent rod, how could I tell? The noise seems to be coming from cylinder 3.
Old Aug 9, 2004 | 10:17 AM
USDM 4G VTEC's Avatar
Default Re: Bent Rod? D16 (turbozxi)
i have blown many D16's (4)
and the engines tap with engine revs, with a spun bearing
i even drove a mini me for 2 weeks with a spun bearing ( and yes it was the #3 also)
u will blow that if u drive it anylonger...
D series will spun a bearing and more likely trow a rod, before bending a rod...
Old Aug 9, 2004 | 09:24 PM
Default Re: Bent Rod? D16 (USDM 4G VTEC)
Thanks for the reply yeah I thought it would snap the rod rather then bend the tooth pic when I started boosting on it the other day, I was running 16psi and seems to go fine no smoke just the noise...
Oh well its back at the mechanics now new engine waiting to go in.
igorka_91
13
Jul 5, 2009 12:29 PM
tdizz07
Oct 27, 2006 08:24 AM
DBallz
May 9, 2003 12:13 PM
Mover
Jul 14, 2002 06:06 PM
