Engine Cranks But will not Start
Old Nov 1, 2002 | 12:10 PM
Hondasaurs's Avatar
Default Engine Cranks But will not Start
I was driving home yesterday and my engine started to sputter as if it was not getting enough fuel. Eventually it stalled. I restarted it with no problem. It stalled again and has not started since. It has 3/4 tank of fuel so it's not out of gas. Any ideas? Is there a way to check to see if the fuel pump is working? All of the fuses are good too.
Old Nov 1, 2002 | 12:23 PM
EVOCELICA's Avatar
New User
Default Re: Engine Cranks But will not Start (ZC_CRX)
check to see if you are getting any spark, it could be the distributor, maybe the coil. check your plugs also.
Old Nov 1, 2002 | 01:01 PM
Nofreee's Avatar
Default Re: Engine Cranks But will not Start (EVOCELICA)
Same thing happened to my buddy with his chevy 1500. Turned out the fuel injectors were clogged according to what he told me.
Old Nov 1, 2002 | 02:04 PM
straightline's Avatar
Like evocelica said, pull a plug wire and check for spark also if you listen care fully you can hear if the fuel pump is turning on or not. If you don't hear the fuel pump that might be your problem check it out.
Old Nov 1, 2002 | 05:03 PM
d-wreck's Avatar
Default Re: Engine Cranks But will not Start (straightline)
yeah listen for the fuel system to pressurize, brrrrrrrrrrrrrrrrmp about a second long on the noise.
check for spark.
my guess would be the coil took a ****. the problem with it running and dying would be consistant with that i would think, just borrow someones for a second and try that if you not getting a spark
also any cel?
derek
Old Nov 1, 2002 | 05:42 PM
TREVER's Avatar
Default Re: Engine Cranks But will not Start (An0therlvl)
I know what happened to buddies c1500 because it happened to mine. But comparing chevrolets primitive injection to a honda is just wrong. Here is what is most likely happening to this car.
The main relay is failing
or the ignitor
or the coil
or the fuel pump.
next time it happens check the fuel pressure and spark
Old Nov 1, 2002 | 07:11 PM
Simple's Avatar
Default Re: Engine Cranks But will not Start (TREVER)
take out the pump and turn on the car, give it some gas, hows the pump suppose to know that the hoses arent connected?
Old Nov 2, 2002 | 07:21 AM
PnX-R's Avatar
Like that dude said.. Check your Fuel Pump Main Relay. If you do a search on here you'll find out how to test it..
95PreludeNAed
Jan 10, 2012 04:09 PM
marcosenid
Oct 30, 2008 04:52 PM
Jabinya
Jul 13, 2007 05:49 AM
patrick4588
May 26, 2006 03:14 PM
Yellow Dragon
Aug 26, 2001 04:38 PM
