electrical question. Installing fog lights
Old Dec 7, 2003 | 08:48 PM
david90's Avatar
Default electrical question. Installing fog lights
Should fog lights be wire parallel or in series to the battery? if my fog lights are 55 watts each, then total amp draw is 55/12v = 4.5 x 2 = 9 amp right? If that is the case then I would need to get a relay that supports 9 amp or above right?
Old Dec 8, 2003 | 09:29 AM
quik1's Avatar
Default Re: electrical question. Installing fog lights (david90)
Ya just get a relay that can support 9 amps then run a power wire off the relay to each fog light. That should work fine, good luck.
Old Dec 8, 2003 | 11:17 AM
david90's Avatar
what is a fusible link?
Old Dec 8, 2003 | 11:27 AM
Wes V's Avatar
Default Re: (david90)
"Fusible link" is a section of wire that is designed to burn up before the rest of the wiring loom goes. If it goes up, you have to find the problem (normally a major item!) and then replace that section of wire.
I'm not sure if they use fusible links in Hondas, but they are always a good idea.
Wes Vann (old guy with a Chevelle history)
Old Dec 8, 2003 | 02:49 PM
Jimmy's Avatar
Global Moderator
Default Re: (Wes V)
Bump for you ...ill be doing this soon
Old Dec 9, 2003 | 05:22 AM
JimBlake's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">... I'm not sure if they use fusible links in Hondas, but they are always a good idea...</TD></TR></TABLE>Seems like Honda likes to use large fuses 'upstream' of the other fuseboxes. Those big 80amp & 100amp fuses that bolt into the engine-compartment fusebox are used instead of fusible links.
And I'd get a relay that can support more than just 9amps. Bulb resistance is lower when cold, so the starting current will be higher for a moment when you first turn them on. It's not nearly as strong as the starting current for an electric motor, but it should be pretty easy to find a relay that can handle 15A.
Old Dec 9, 2003 | 12:19 PM
mike1114's Avatar
Default Re: (JimBlake)
I could be wrong but most fog lights wiring (including stock honda) uses a 30 amp relay. iF you buy from honda $35.00. From Radio Shack or a place near my house called skycraft, its only $0.49 cents.
Old Dec 9, 2003 | 12:33 PM
Wes V's Avatar
Default Re: (mike1114)
I don't know the price, but what you want is a Bosch 0 332 204 150 relay. Use a section of fusable link in the wire that goes directly to the battery.
If you want more information try this link;
http://www.chevelles.com/tools/ftl3.html
Wes
civicSIfnatic
13
Aug 21, 2008 09:48 PM
hayman
Oct 8, 2007 07:25 PM
theciv
Honda Civic (2001 - 2005)
Apr 24, 2007 06:07 PM
Azxster
Audio / Security / Video
Apr 20, 2007 06:38 PM
Francesco
Honda S2000
13
May 31, 2006 03:16 PM
