Electrical Problem: Fans not working in DA
Old Mar 23, 2005 | 05:40 PM
intake's Avatar
B A N N E D
Default Electrical Problem: Fans not working in DA
the reason y my car has been over heating is that my fans dont work.. i drive a 92 integra RS with a b16a2 swap JDM..
How can i rewire my fans or something? I hate putting the heater on full blast to cool my motor down..
Old Mar 23, 2005 | 07:24 PM
integrator43's Avatar
Default Re: Electrical Problem: Fans not working in DA (intake)
check your fan switch, if it is bad your fans are non-op. if the switch is bad you can just jump the two wires and presto the fans will work..... so long as nothing else is wrong.
Old Mar 24, 2005 | 04:14 AM
JimBlake's Avatar
Driving down the road at 40mph pushes more air thru than the fans. So if it overheats even while you're driving, then the fan's aren't your only problem.
Old Mar 24, 2005 | 01:07 PM
Default Re: Electrical Problem: Fans not working in DA (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Driving down the road at 40mph pushes more air thru than the fans. So if it overheats even while you're driving, then the fan's aren't your only problem.
Good point Jim!
Old Mar 26, 2005 | 11:16 AM
intake's Avatar
B A N N E D
Default Re: Electrical Problem: Fans not working in DA (integrator43)
nono it cools down but city driving she starts over heating.. i mean.,. once she gets to a certain point my car wont let me shift passed 4.5k cause shes hot,, its like a safe guard or something in my ecu
kinda sucks,., cause then i cant reach vtec at 5k.,. and 4.2k is 75 mph.. and 4.5 is about 80..
driving on long trips i discount vtec cause at 5k is 90.. i got a jdm b16 cable tranny,,, high gear ratios
Old Mar 26, 2005 | 07:27 PM
str8boost's Avatar
unplung coolant sensor near thermostat housing, try jumping ure fan out , use a paper clip, if fan turns on, check for bad sensor...
American.Graffiti
10
May 29, 2007 05:06 PM
PuiPui
Aug 28, 2006 05:13 PM
iphatcrxi
May 21, 2006 03:06 AM
bluesi00
Jan 7, 2004 09:15 PM
b16_madman
Nov 15, 2003 04:59 PM
