ECU error code
Old Aug 4, 2003 | 11:45 PM
Jasper777's Avatar
Default ECU error code
I have an error code of 2
two short blinks.
Does anyone know what it means? Is it serious?
H22A and an auto tranny!
Old Aug 5, 2003 | 05:40 AM
Prelude Vtec 23's Avatar
Default Re: ECU error code (Jasper777)
Its probably two long blinks which is a code 22.
VTEC System Malfunction
Probable cause:
VTEC Solenoid Valve
Open or Short in VTEC Solenoid Valve circuit
VTEC Pressure Switch
Open or Short in VTEC Pressure Switch Circuit
ECU
Old Aug 5, 2003 | 07:15 AM
JimBlake's Avatar
Default Re: ECU error code (Prelude Vtec 23)
2 long blinks would be 20, not 22.
ELD - electrical load detector.
Old Aug 5, 2003 | 12:23 PM
Default Re: ECU error code (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">2 long blinks would be 20, not 22.
You are 100% correct..my fault.
Old Aug 5, 2003 | 06:26 PM
Jasper777's Avatar
So what can I do to fix it?
What is it actually.
I heard it can also be a secondary 02 sensor.
Would any of these force the car into safe mode?
Old Aug 6, 2003 | 03:56 AM
JimBlake's Avatar
Check out...
https://honda-tech.com/zerothread?id=576396
What car exactly? You're in Bangkok? So that's more complicated. Some of that stuff is different for different countries. The Helm shop manual for my '95 Integra says the ELD is only installed in US cars, but the manual only covers North America anyway.
If it was the secondary O2 sensor it would throw a different code.
edit...
You did say at first that it was 2 short blinks. I don't know the list of error codes for your car, so maybe that would be the second O2 sensor? How long are the blinks?
Modified by JimBlake at 8:12 AM 8/6/2003
keychild486
11
Apr 2, 2008 06:28 AM
ITR0950
Oct 18, 2007 10:10 AM
four o two
Dec 22, 2005 11:47 AM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
gots_a_sol
Aug 4, 2004 05:32 PM
