ecu code 7 TPS
Old Sep 24, 2004 | 09:33 PM
dnatrance's Avatar
Default ecu code 7 TPS
ok I just finished swapping out my auto ls for a b18c. Everything is cool, but I get a mil for my tps. I replaced it with a new one and same thing. Now I did just read in a acura manual that the tps runs to the TCM (traction control module??) it shows this only for the automatic. Where is the TCM and is that the reason I keep pulling a code 7?
any input would be appriciated
Old Sep 24, 2004 | 10:34 PM
TurboLSVtecTeg's Avatar
Default Re: ecu code 7 TPS (dnatrance)
Check the voltage on the signal wire on the TPS and make sure its at .5V when the throttle is closed. This could be why its throwing the code. I also think its right around 5V at 100% throttle.
Sal
Old Sep 24, 2004 | 10:49 PM
dnatrance's Avatar
Default Re: ecu code 7 TPS (TurboLSVtecTeg)
I do not get a signal back from the computer side... I am going to have to splice the plug by the tps to read what it is putting out.
but have you heard of people with auto integra's (obd2) swapping over to standard having this problem? I am also using a obd1 computer box
Old Sep 25, 2004 | 01:57 AM
Hmm ok so the wiring is wrong on the auto to manual swap. Yea that could cause a problem if the TPS is reading wrong. As I would guess auto trannies calculate what RPM to shift at depending upon load for the most part among other things.
Ill try and find out where the TCM is located on an auto car.
Sal
Old Sep 26, 2004 | 06:20 PM
dnatrance's Avatar
ok I got I figured it out. When we put the new one on it didnt get in the notch right. Anyway I the tcm is at the drivers side kick panel
thanks
evo500
13
May 25, 2010 11:10 AM
z6htch
13
Nov 25, 2008 02:44 AM
FOMULA91
Oct 4, 2007 01:16 PM
your username here
Nov 29, 2003 04:58 PM
