ecu code 14, 54 , & 65 at the same time?? HELP!!!!
Old Sep 23, 2002 | 11:13 AM
FLIPboi's Avatar
Default ecu code 14, 54 , & 65 at the same time?? HELP!!!!
im throwing thes codes at the same time any one knoe what these codes are , ????
Old Sep 23, 2002 | 12:24 PM
r0cketman49's Avatar
Default Re: ecu code 14, 54 , & 65 at the same time?? HELP!!!! (FLIPboi)
here's some code descriptions
http://tech.hybridgarage.com/tech/codes.html
http://www.151boost.com/tech2.htm
Old Sep 23, 2002 | 01:17 PM
Spade's Avatar
14 IACV (idle air control valve)
54 Crank fluctuation sensor (behind the crank pulley) I have had one for a while.....still not going to fix it...
65 Seconardy O2 sensor.
Old Sep 23, 2002 | 08:17 PM
FLIPboi's Avatar
Default Re: ecu code 14, 54 , & 65 at the same time?? HELP!!!! (Spade)
yea i figer my idle iz bad but i got the idle air fixed and the o2 but not the crank sensor iz thier a way to by pass it ??
Old Sep 23, 2002 | 08:33 PM
MikeSarr_GSR's Avatar
BUAH HAH HAH, you are joking right, yo?
Old Sep 23, 2002 | 09:00 PM
FLIPboi's Avatar
Default Re: ecu code 14, 54 , & 65 at the same time?? HELP!!!! (MikeSarr_GSR)
aiigth heres the senario i did a swap in my 96 civic hatch , and the motor i got wuz free witch iz a 90 ls motor but i rebuilt the whole thing with after market stuff , and when i wuz done i wuz trowing the crank speed code and so i caonverted my moter to obd 2 and not im missing the sensor but the the old distributer off of the motor i had the sensor wuz in the distributer so wut i wuz guna do wuz do sum wire majik (ghetto stuff) and try to wire the crank sensor plug to the old distrbuter idonno if it will work but im gunna try i got nothing to loose , but one thing iz i lost my daym wire diagrams so im out of luck for now , but if it wokz ill keep yall updayted , dose any one have control system wire diagrams???for a 96 civic and 90 ls,??
Keno Smith
Nov 5, 2012 10:56 AM
EFjoe91
Dec 28, 2010 01:36 PM
sierrakilo
Nov 14, 2006 07:56 AM
SmogKing
Aug 10, 2006 01:59 PM
RedEj8
Dec 4, 2005 05:46 PM
