ecu code 14, 54 , & 65 at the same time?? HELP!!!!
here's some code descriptions
http://tech.hybridgarage.com/tech/codes.html
http://www.151boost.com/tech2.htm
14 IACV (idle air control valve)
54 Crank fluctuation sensor (behind the crank pulley) I have had one for a while.....still not going to fix it...
65 Seconardy O2 sensor.
aiigth heres the senario i did a swap in my 96 civic hatch , and the motor i got wuz free witch iz a 90 ls motor but i rebuilt the whole thing with after market stuff , and when i wuz done i wuz trowing the crank speed code and so i caonverted my moter to obd 2 and not im missing the sensor but the the old distributer off of the motor i had the sensor wuz in the distributer so wut i wuz guna do wuz do sum wire majik (ghetto stuff) and try to wire the crank sensor plug to the old distrbuter idonno if it will work but im gunna try i got nothing to loose , but one thing iz i lost my daym wire diagrams so im out of luck for now , but if it wokz ill keep yall updayted , dose any one have control system wire diagrams???for a 96 civic and 90 ls,??
sierrakilo
Nov 14, 2006 07:56 AM
SmogKing
Aug 10, 2006 01:59 PM
