Is 10.5:1 compression too high
Old Dec 9, 2002 | 04:45 PM
7rrivera7's Avatar
Default Is 10.5:1 compression too high
I'm running JE SRP pistons and want to go turbo. Some people tell me I need to swap out my pistons for lower compression ones like 9:1. Others tell me I can use these pistons, just don't boost more than 10 lbs.
I read before that it's all relative - lower compression pistons handle more boost and higher, less. In fact, it's better to start out with higher compression and use less boost than to make the same power with lower compression and higher boost.
What should I do?
Old Dec 9, 2002 | 04:47 PM
C-Murdock's Avatar
Default Re: Is 10.5:1 compression too high (7rrivera7)
some guy made 560whp on 11:1 Pistons and 20 some psi of boost...
Old Dec 9, 2002 | 04:53 PM
DLB1994's Avatar
Default Re: Is 10.5:1 compression too high (C-Redrum)
if you do get a standalone atleast hondata with some 550cc's
am running 10.2:1 am getting hondata with 720's now
Old Dec 26, 2003 | 04:46 PM
Code Blue's Avatar
Default Re: Is 10.5:1 compression too high (DLB1994)
i've got the 10.5:1 CP's in now. i will be pushin turbo soon
Old Dec 26, 2003 | 04:54 PM
FOrSfEd's Avatar
Default Re: Is 10.5:1 compression too high (Code Blue)
high compression
Boost
tuning
Old Dec 26, 2003 | 04:56 PM
infinatenexus's Avatar
High compression+boost=seat of the pants fun
Old Dec 26, 2003 | 04:58 PM
b16ahybrid's Avatar
Default Re: Is 10.5:1 compression too high (FOrSfEd)
just tune it good and you'll be fine
Old Dec 26, 2003 | 11:12 PM
turbopimp's Avatar
The RSX type S has 11.0 cr and has been boosted to 10+ psi on 93 octane pump gasoline. Not sure of gas quality in PR, though.
Old Apr 20, 2004 | 01:02 AM
ccsmith1999's Avatar
Default Re: Is 10.5:1 compression too high (turbopimp)
didnt he have to play with timing and injectors?
Old Apr 20, 2004 | 02:14 AM
Soon_2b_evil's Avatar
Default Re: Is 10.5:1 compression too high (xeugep)
get you some 700cc injectors, Fuel management system, Spend some money on someone WHO know the system and KNOWS what they are doing. you'll be fine with 10.5:1. Im doing the samething with my setup.
Remember its your setup dont let someone tell you different.
Old Apr 20, 2004 | 03:46 AM
MiraiZ's Avatar
Default Re: Is 10.5:1 compression too high (Soon_2b_evil)
Easier to tune with lower comp. You loose very little low end power, but you'll never notice!
snaileg
Nov 8, 2006 04:11 PM
RTst92
Mar 5, 2006 01:56 PM
B94Cast
Oct 26, 2003 09:45 AM
7rrivera7
Oct 23, 2002 06:58 AM
thinkbrianthink bu
Oct 13, 2002 10:47 AM
