How much boost...
Old Oct 22, 2002 | 11:02 AM
7rrivera7's Avatar
Default How much boost...
I have JE SRP 10.5:1 pistons on my B16 and want to go turbo. I've been told I have to get lower compression pistons. I installed a block guard and plan to install Eagle rods before going turbo.
Can I keep these pistons with mild boost or should I swap them. If I have to swap them, what compression should I choose? If I don't swap them, how much boost can I push?
Thanks!
Raul
Old Oct 22, 2002 | 11:20 AM
highbrid's Avatar
Default Re: How much boost... (7rrivera7)
that cr is fine, youll be faster with that cr than with say 8:1, especially if youre running real low boost. you may want to look into some sort of fuel management or fuel system upgrades though. dont lower your compression, itll be fine
how much boost you run depends on your tuning
[Modified by highbrid, 11:31 PM 10/22/2002]
Old Oct 22, 2002 | 03:05 PM
grngsr01's Avatar
Default Re: How much boost... (highbrid)
Read this in this forum a while ago. I saved it cuz it seems like good info.
One main concern in power production with forced induction is effective compression. Effective compression is the sum of the motors static compression, plus the additional compression added by the forced induction tool. A B18C1 (also B16A) motor will have a higher effective compression than a B18B motor will, on the same boost...therefore, pound for pound, it will make more power.
The next argument that people usually bring up is that a higher compression is bad for turbocharging. Well, if you understand the concept of effective compression, then you should understand that this statement is entirely incorrect. A higher compression engine makes more power in NA form. So, why do you turbo guys think that a lower compression turbo motor makes more power? Does that make any sense when you really think about it? A turbocharger is a power adder? So why deplete power that was there to begin with? The answer I usually get to that is "So I can run more boost!" Well, sorry to rain on your parade, but more boost does not always equal more power. Check out this mathematical example of effective compression:
A motor with a 10.0:1 static CR boosting 10psi
10psi/14.7psi = .68
.68 + 1 = 1.68
1.68 x 10 = 16.8 effective CR
A motor with an 8.5:1 static CR boosting 10psi
10psi/14.7psi = .68
.68 + 1 = 1.68
1.68 x 8.5 = 14.28 effective CR
Now tell me who is going to make more power? The higher CR motor, or the lower CR motor?
So, maybe add more boost to the lower CR motor, right? Wrong...
A motor with an 8.5:1 static CR boosting 13psi
13psi/14.7psi = .88
.88 + 1 = 1.88
1.88 x 8.5 = 15.98 effective CR
Now you see, even adding 3psi of boost, still does not equal the effective CR of the higher compression, lower boost motor.
Effective compression is not the only advantage of the B16A/B18C1 either. The B16A/B18C1 has a stronger, better flowing cylinder head. It can rev much higher, making it that much more effective, and it flows great to handle all of the extra volume. The block has oil squirters to help support the bottom end assembly at high RPM. It takes more than a valvetrain upgrade to make a B18B safe at 8k. The higher compression also aids in spooling the turbo faster too.
Both motors have similar tolerances though. Both motors pretty much top out at around 350-400hp on stock motors, very well tuned. The B18C1 will make it far more efficiently for you though. It takes less boost to do so, it has more safeguards...and the bottom line on any Honda motor is tuning. If it is well tuned, you will be set. That goes for both motors. YOU ARE A FOOL if you think for one second that just because your B18B has a lower compression, you can substitute that for proper tuning.
A lot of people like to lower their motors compression when they build their motor. I used to think it was a good idea before I understood about tuning, and the positive aspects of compression. In the mathematical representation below, I will show you how a low compression motor must boost more to equal the output of a higher compression, lower boost motor:
Motor: stock B16A2 boosting 7psi.
Static Compression Ratio: 10.4:1
((boost psi / 14.7) + 1) x motor compression = effective compression
Stock motor (10.4:1 CR) on 7psi:
7psi/14.7psi = .47
.47 + 1 = 1.47
1.47 x 10.4 = 15.288 effective CR
Built motor (9.0:1 CR) on 7psi:
7psi/14.7psi = .47
.47 + 1 = 1.47
1.47 x 9 = 13.23 effective CR
You will lose 2.058 points from your effective compression ratio, this translates to a significant power loss.
In order to gain back that power, you have to do this:
Built motor (9.0:1 CR) on 10.5psi:
10.5psi/14.7psi = .71
.71 + 1 = 1.71
1.71 x 9 = 15.39 effective CR
Add 3.5psi to what you were boosting before, and you should be able to make around the same power as before, granted you haven't done any other kinds of modifications port/polish, cams, etc...
As you can see, considering all things stay equal (bore/stroke/cylinder head/etc...), you must add 3.5psi to make the motors perform similarly. You just spent about $2,500 to build your bottom end, and make your car slow.
By now we all should understand the positive aspects of compression, and how when teamed with the faster spoolng turbo, more efficient output, better flowing B-series VTEC cylinder heads, better low end spool time, stock oil squirters, higher redline, etc...you should see that turbocharging B-series VTEC motors is clearly not dangerous, and highly adviseable. I love a good turbo B16A.
is this making any sens????
Old Oct 22, 2002 | 04:04 PM
W.Zero's Avatar
Default Re: How much boost... (grngsr01)
what grngsr01 is saying is true theres been a war between low and high compression turbos. im low but i know high works too. from what i seen is that cars with high comp. dont have as much lag.
dude my boy in turboing in si that has comp. of 10.8:1!!
just boost!!!!!!!!!!!!!!!!!!!!
[Modified by W.ZeroB18C1T, 5:05 PM 10/22/2002]
Old Oct 22, 2002 | 04:16 PM
symba's Avatar
Default Re: How much boost... (W.ZeroB18C1T)
The only problem with running high comp (9.5:1 and higher) is if you are running higher boost levels..>20psi..you have to be very precise with fuel management. There is no room for error and chances are, you would also have to run higher than 93 octane. For your application, I agree that your compression is fine as long as you have better than average fuel management
Old Oct 22, 2002 | 04:39 PM
TurboedGSR's Avatar
an easier way to remember that is (boost psi+14.7/14.7) x motor compression=effective compression
Old Oct 22, 2002 | 05:51 PM
avividmemory's Avatar
Default Re: How much boost... (TurboedGSR)
is not the same as
example:
((10/14.7)+1) x 10.0:1 cr=effective comp.
((.68)+1)x10.0:1
(1.68)x10.0:1=16.80 effective comp.
(10+ 14.7/14.7)x10.0:1=effective comp.
(10+1)x10.0:1
(11)x10.0:1=110???
order of operations guys...(10+ 14.7/14.7)x10.0:1=effective comp....division first before addition in parenthesis...
stick with this one...((boost psi / 14.7) + 1) x motor compression = effective compression...that is why there is two sets...to seperate them
i could be putting my foot in my mouth later, but thats what i get from all that
Old Oct 22, 2002 | 06:58 PM
BlueSi2k's Avatar
Default Re: How much boost... (SpoolinLS)
it should be..
( ( boost psi+14.7 ) /14.7) x motor compression=effective compression
its boost psi + 14.7 all over 14.7
[Modified by BlueSi2k, 10:58 PM 10/22/2002]
Old Oct 23, 2002 | 06:58 AM
TurboedGSR's Avatar
Default Re: How much boost... (BlueSi2k)
yea thats what i meant add first then divide by 14.7. The reason i said that is because at first I was a little confused as to where you got the +1 so my equation makes it a little easier to undestand, sorry if i confused anyone
99siRACER
Jan 3, 2012 12:20 AM
snaileg
Nov 8, 2006 04:11 PM
RTst92
Mar 5, 2006 01:56 PM
7rrivera7
Apr 20, 2004 03:46 AM
thinkbrianthink bu
Oct 13, 2002 10:47 AM
