Thicker or OEM head gasket?
Old Feb 22, 2006 | 01:25 PM
Jason703Racing's Avatar
Default Thicker or OEM head gasket?
My EM1 is about to go boost here in the next month or so and will be using a inline pro turbo kit. Question is I want the car to be safe around 250-300whp TOPS is the much i want out of it and I was wondering should I get a thicker head gasket to lower compression or no? Ive talked to a few people some say to do it same say dont. My old hatch without a thicker head gasket on 9psi on a b16a running a gt32-51 turbo did 259whp and runs good. My new EM1 though I was thinking about doing one to be safe but if its not worth it then why do it? So my question to you guys is. Should i get thicker head gasket or no?
Jason
Old Feb 22, 2006 | 01:52 PM
Riake's Avatar
Default Re: Thicker or OEM head gasket? (Black00EM1)
Using a thicker one has the chance to be safer. However if you do get a thicker one, while the head is off and you are doing your thing, i would go ahead and get some ARP head bolts, golden eagle, yada for increased sealing and clamp force.
Old Feb 22, 2006 | 02:48 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: Thicker or OEM head gasket? (Riake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake &raquo;</TD></TR><TR><TD CLASS="quote">Using a thicker one has the chance to be safer. However if you do get a thicker one, while the head is off and you are doing your thing, i would go ahead and get some ARP head bolts, golden eagle, yada for increased sealing and clamp force. </TD></TR></TABLE>
get some ARP head studs if you do get a new gasket. if you get a thicker head gasket and lower the compression, it will be safer but you will sacrifice power too. do you have stock internals? for up to 300whp, i think you'll b fine but highly recommend investing in sum head studs instead of a new gasket
Old Feb 22, 2006 | 06:12 PM
Default Re: Thicker or OEM head gasket? (JDM turbo DC)
Yea I would deff do that, I would put ARP bolts on there when or if I do pull the head off for a new gasket. Maybe Ill just run the stock head gasket till it starts to leak then pull and do the studs/thicker head gasket. I mean 250whp Should be no problem on stock head gasket for now. Am i right or wrong?
Old Feb 22, 2006 | 06:57 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black00EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Yea I would deff do that, I would put ARP bolts on there when or if I do pull the head off for a new gasket. Maybe Ill just run the stock head gasket till it starts to leak then pull and do the studs/thicker head gasket. I mean 250whp Should be no problem on stock head gasket for now. Am i right or wrong? </TD></TR></TABLE>
Yup ull b all right with stock ones
I'm using one w/7psi 240whp and its running good and my tuner said if I only have boost control and aem fpr I would've got higher number safe @ 9psi so
Good luck
Brycen
Jan 1, 2010 02:20 AM
arielmalespin
Mar 13, 2007 02:32 AM
NSfit
Sep 20, 2006 06:43 PM
Brycen
Mar 3, 2006 02:43 PM
dabomb
Sep 27, 2003 04:51 AM
