Do I need to plug this up?
Old May 4, 2007 | 09:02 PM
hotrod99's Avatar
Default Do I need to plug this up?
Modified by hotrod99 at 11:02 PM 5/4/2007
Old May 4, 2007 | 09:08 PM
hotrod99's Avatar
Default Re: Do I need to plug this up? (hotrod99)
what is the hose supposed to run to?
Old May 5, 2007 | 06:15 AM
shifts's Avatar
thats ur fitv hose. coolant is suppose to run through there.
Old May 5, 2007 | 08:51 AM
hotrod99's Avatar
Default Re: Do I need to plug this up? (shifts)
Is it needed on boosted setup's?....and can I plug just one of the holes to the fitv?
Modified by hotrod99 at 10:01 AM 5/5/2007
Old May 5, 2007 | 09:10 AM
SlowReaction's Avatar
How do you expect coolant to flow through if it blocked? Have you looked at what that other hose that is on the other end goes to?
Old May 5, 2007 | 09:27 AM
maciag's Avatar
Default Re: Do I need to plug this up? (SlowReaction)
-deleted post-
said something really dumb
Old May 5, 2007 | 10:52 AM
hotrod99's Avatar
Default Re: Do I need to plug this up? (maciag)
where does the hose go to?
Old May 5, 2007 | 11:47 AM
inspyral's Avatar
That's just the throttle body heater. You can either run coolant through it to heat your throttle body, or you can bypass it. If it never gets below freezing where you live, I would just bypass it. You do not have a FITV despite what previous posts say. Coolant runs in the front nipple and out the rear one to the IACV as seen in that pic. If you want to bypass the TB heater, just run coolant directly to the IACV and leave both TB heater nipples open(or cap them with a vacuum cap or something). If you want to run the heater, there should be a port on the head, just under where the upper radiator hose attaches. Coolant runs from there to the front of the TB, out the back of the TB, on to the IACV, and then to the big water tube on the back of the block.
Old May 5, 2007 | 12:11 PM
hotrod99's Avatar
Default Re: (inspyral)
THANK YOU!! .....thats all i wanted to know
thexbrothers
Sep 29, 2013 03:45 AM
jtac616
Oct 10, 2012 04:25 AM
Jdmtuned
Apr 23, 2009 11:00 AM
I B BANGGIN
Aug 12, 2007 04:32 PM
oOPreludeBoyOo
Jul 13, 2003 02:56 AM
