Distributor problems?
Old May 3, 2009 | 03:05 PM
1badcrx's Avatar
Default Distributor problems?
my car was running very spotty, bogging down. then one day it just died all together and wouldnt start back up. It was giving me a 21 code. vtec solenoid, i thought it was the distributor... so i cleaned out the solenoid and it still wouldnt start. so i checked the spark, none at all. i had the coil and the igniter tested. the igniter was bad so i purchased a new one and still no spark. i put a new rotor cap and distributor cap on, still no spark. At this point i'm lost and completely frustrated. Could it be that i just need to repalce my distributor?
Thanks
Old May 4, 2009 | 09:21 AM
delbert's Avatar
Default Re: Distributor problems?
yes just replace it. maybe ur coil is bad ? my coil was bad in mines and was boggin after it warmed up like 10mins then would eventually die...
Old May 4, 2009 | 12:06 PM
nihad's Avatar
so if the coil is bad why doesnt buying a new coil fix the problem
Old May 8, 2009 | 08:21 PM
camden's Avatar
same problem, bump
Old May 9, 2009 | 12:58 AM
JBTuning's Avatar
H-T Platinum Sponsor
Wires good? all on the correct firing order sequence?
JBTuning's Avatar
He said the coil has already been tested.
1badcrx
May 6, 2009 12:25 PM
pdc125
May 15, 2005 02:26 AM
SI_niki
Jun 15, 2004 07:54 AM
duckming
Jun 5, 2003 05:17 PM
dlric
Dec 13, 2001 03:55 AM
