distributor problem
So I got a code 4 on my 96 Honda civic hatch obd2 to obd1. The code is ckp which is located in the distributor so I got a new one. Put it on and went to start it and nothing so I checked a few things out and thought let me look at the distributor again. I pulled it and the shaft that goes in the motor the 2 prongs where cut off. Wharf causes that to happen. Is there something wrong with my motor or is it cause the new one had aluminum prongs.
I had the old distributor and it was made of steel. So I toolk both apart and and swapped out the bad on the new and replaced the shaft with the old looks good. All I really needed tl do was swap out the sensors and call it a day but why not use the new. But I am still lime what would cause it so shear off. And help would be greatly appreciate
JBirch_97Prelude
Jun 25, 2006 12:31 PM
2muchPSI
Jun 27, 2003 12:23 AM
