Distributor problem
Old Jun 28, 2009 | 03:23 PM
raene's Avatar
Default Distributor problem
Running into an issue with a TD44U distributor (OBD1 VTEC distributor) on a B20VTEC. I have it fully advanced and it will only put out 15* advance at the crank. Freelog says it's outputting 20* and that's what I have it tuned to at idle in Crome.
What could cause such a massive amount of retard to happen from the distributor itself?? It's an internally stock aftermarket replacement (basically Distributor King).
Old Jun 29, 2009 | 02:56 AM
delsolproblems's Avatar
Default Re: Distributor problem
The timing belt could be off a tooth. Could be the wrong cams for the app.
Old Jun 29, 2009 | 08:01 AM
raene's Avatar
Thanks for the post... I checked both of those things Stock JDM B16 cams and I checked the timing belt.
I'm using a Fluidampr Street dampener, does anyone know if the timing mark is "off" on these things, perhaps?
MastaFlyMason
Oct 2, 2016 02:53 PM
jakscivic
Jun 2, 2010 07:29 PM
96a-ccord
Feb 26, 2010 02:04 PM
sitinthehall
May 2, 2007 04:16 PM
LB CRX
Jul 24, 2002 08:14 AM
