How do i know if my distributor is bad?
and does anyone live in Vallejo that would like to help me out that has a manual 1993 del sol? I really don't wnna buy a distributor and turns out it's not the problem and they cost a lot and not refundable so if anyone can help me i wud greatly appreciate it just PM me if ur interested
Re: How do i know if my distributor is bad?
RPM is jumping, sumtimes just stalls, u can buy a used one on here and try to if it fixes yur problem
Does the engine lack spark? Did you retrieve a distributor sensor code from the ECU?
If there's no spark and no distributor sensor codes, then remove and test the coil and igniter unit in the distributor. Some auto parts stores will do this for you. Also, do you measure battery voltage on the Black/Yellow wire attached to the igniter unit with the key in ON(II)?
I'm not Rick!
Ronj@aHt...how did you learn all this stuff? i think you should make a sticky of complex solutions to complex problems that are beyond the basics. not to thread jack, jus an idea
It listen to him^^^....but yea, it could be something as simple as your rotor, or coil.
Well the mechanic said change the ignition coil in the distributor first so we did, bought a new one on ebay and replaced it and now it won't turn on before we replaced the IG coil tho it was turning on and staying on but it shakes erratically and no matter how much u press accelerator it won't go
Generally when you have ignition problems with these old cars, most of us recommend buying a rebuilt dizzy. There about $170.00 and comes with all new internals.
How much did you pay for the coil ?
i noticed that. You must have read those books so many times lol because you seem to know them like the back of your hand. I dont have that, so I go from the knowledge that i already have from experiences that me or one of my friends has had that I have helped them out with. Or stuff that I have learned on here or other places from more knowledgeable people
Yeah, I too rely on these important types of experiences and then use the service manuals to make sure I get the details right.
my car isn't getting any spark at all and i just changed my distributer cap not to long ago and i checked and it's not getting a spark at the plug.
